Aston Martin Red Bull Racing TAG Heuer RB14
Re: Aston Martin Red Bull Racing TAG Heuer RB14
Old vs new.
Godius
186
VER/RIC RW comparison, via AMuS:
Godius
186
Ricciardo lost parts of the the upper elements of his FW on both sides during the race it seems:
edit (motorsport):
Brake Horse Power
Brake Horse Power
After qualy he did say the low DF setup would have been a better choice :roll:
Sieper
73
He lost those elements to the left hand side just prior to the pitstop, there is a Pic of him leaving the pits with them missing (and later on another with Kimi in the background, so just before he got overtaken, I think the right hand side was still there at that time).
They must have been lost (right hand side) very late in the race, certainly a construction error, this cannot be a coincidence of debris hitting twice.
The image cannot be mirrored as the driver info panel is on the left hand side (which is the correct place).
roon
roon
412
Look closely and you'll see the upper two vanes broke at approximately the same location on both sides, inboard of the pivoting carrier they use to adjust flap angle.
zibby43
zibby43
613
roon wrote:
25 Jun 2018, 18:55
https://d3cm515ijfiu6w.cloudfront.net/w ... 11111.jpeg
https://www.jamesallenonf1.com/wp-conte ... 067688.jpg
Structural failures or debris strikes?
ScrewCaptain27
577
zibby43 wrote:
26 Jun 2018, 23:03
roon wrote:
25 Jun 2018, 18:55
That appears to be a failure. Both flaps broke exactly in the same spot, on the adjuster pivot point.
- Serj Tankian
zibby43
zibby43
613
ScrewCaptain27 wrote:
27 Jun 2018, 09:38
zibby43 wrote:
26 Jun 2018, 23:03
roon wrote:
25 Jun 2018, 18:55
I agree 100%. I guess I was just hesitant to believe, initially, that lightning could strike twice there on such a critical component.
JonoNic
Wouldn't that be the perfect place in the FW to cause some form of deflecting (not the correct term) to decrease drag on the straights? Unfortunately failure was caused by the grippier asphalt caused higher cornering speeds for longer than anticipated in the race.
lio007
319
When did they revert back to last years suspension internals?
old:
10 May 2018, 21:21
Front suspension internals (via Scarbs):
New, Austria(Thursday):
Godius
186
Bargeboard detail, via AMuS:
Via AMuS
Ricciardo has this at the front to match his skinny RW.
