Hi all,
Several months ago I posted a thread about gravity racing (essentially just grown-up soapbox car racing) and some questions about the current 102mph record holding car, and how it could be bettered.
viewtopic.php?f=14&t=26724
Through that thread i was fortunate enough to meet an aerodynamic engineer who has been key in moving the project forwards, but between us, there are still a few grey areas regarding the aerodynamic implications of having a flat floor.
A flat floor is ideal for us for a few reasons:
1. Low CofG. The car will hopefully be doing 100mph at the bottom of the hill, where it has to go round a sweeping right hand curve. With a proposed 600mm track width, we feel keeping it low is essential for grip, and certainly for driver confidence just with the way it will look.
2. A flat floor will make the body shell much easier to make, as we will essentially only need to make the "top half" of a traditional streamlined shape.
Early drawings and CFD analysis show good improvements over the car we're trying to beat, but the issue of the flat floor still plays on my mind. The KEY aim is low drag for top speed, with the ability then to take a 100mph bend. We figure this means a car with neutral aero, with a slight tendency toward downforce in the lowest drag way possible.
Given a "Cockroach with Flat Bottom" shape, what are the implications of the flat floor? Would it give any downforce without a diffuser? Would, say 30mm ride height be significantly different to a 100mm ride height? What difference would it make?
Regards,
Jim
