saviour stivala wrote: ↑19 Jul 2018, 19:13
dans79 wrote: ↑19 Jul 2018, 15:42
The diagram even says unlimited on it.....
Yes the diagram says unlimitted up to "K" but limitted from "K" OUT or IN.
Is this what you are referring to?
[/url]
If so, the "Limited" from the MGU_K to the Rear Wheels and vice versa is ONLY a POWER limitation, which is why you see the "+/- 120KW" qualifier. 120kW is a power measurement, not a flow measurement. All it means is that the MGU_K can operate at a max of 120kW(160HP), whether it is sending the power to the wheels or the ES or the MGU_H. "Flow" is a quantity of energy, measured in megajoules in this case. 1kW is a kilojoule per second. The difference here is power and flow. The MGU_K has a limited amount of flow from the ES only, as the diagram shows. However, whether it gets the flow from the ES or the MGU_H or from the ICE (when generating), it can only operate at 120kilojoules per second.
Again, the only limits are flow from the ES to the K and vice versa, and the POWER from the MGU_K. Flow from the ES to MGU_H and vice versa is unlimited. Flow from the MGU_H to the MGU_K is vice versa is unlimited. The diagram is clearly labelled. How exactly are you interpreting this as FLOW being limited from the MGU_K to the wheels/ICE? Flow doesn't get sent from the MGU_K to the wheels/ICE at all, in fact. POWER gets generated and torque gets applied.
Human history is the long terrible story of man trying to find something other than God which will make him happy.
