"Bottas makes up a lot of time in the 2 final corners (truly one big double apex corner)."
I had a laugh at the corner numberings here. Why is every tiny change labeled a corner for the calendar's circuits? I can't count and memorize all of these corner numbers. I count 12 corners if generous, and for an F1 car there are effectively just 7 corners that matter. (1, 2, 6, 8, 12, 13, and 16-17 which is one multi-radius corner)
Speaking of turn 1 ... Max took it flat out in qualifying! Wow. The only driver to do so.
Discussing Ferrari's PU advantage by going by that long straight GPS data... wouldn't all the PU's be mapped to maximize electrical output for this straight? At least to an extent that is very similar to each other. So wouldn't that make it a reliable straight to estimate HP from?
Thanks!
