Radial inflow turbines don't do that when motored. If anything they tend to flow in reverse to the normal direction.cheeRS wrote: ↑25 Jul 2018, 01:04I wonder if Ferrari have found something extra if the electric S/C mode is the differentiator. The one unorthodox thing about the electric SC mode is that the turbine is still linked (whereas a 'normal' electric SC wouldn't have a turbine at all), and thus becomes a fan/vacuum pump for the exhaust. This would ostensibly remove any backpressure and maybe even create a more ideal vacuum for the combustion chamber?
Mixed flow (radial/axial) turbines have less tendency to oppose flow when motored.
Either way, it is almost certain that blowdown pulses are still being forced through the turbine with wastegates open, to capture some valuable energy during "electric supercharger" mode.
