Honda RA108 aero-mech development in 2008
bar555
bar555
FRONT WING AUSTRALIA
Double profiled front wing
1.Deep rather boxy spoon shape , the major amount of front downforce is produced by the central part of the wing . This makes the wing less influenced by side wings ( when the car turns ) .
2. Τhe outer extremities of the main flap are bending upwards to create a gap between the wing profile and the ground in order to reduce the pitch sensitivity of the car at high speed
3. Curved pillars
4. Venturi Channel
5. Τhere is not any winglet on the endplates
6.The endplates have a vertical shape and a sharp cut at their upper profile . They bend inwards in order to guide the airflow to the inside profile of the front wheels
7.Vertical fin under the wing
8.Connection between the wings
9. The second flap is wider under the nose cone compared to winter testing
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
bar555
bar555
Re: Honda RA108 aero-mech development in 2008
FRONT WING MALAYSIA
Similar to Australia
FRONT WING BAHRAIN
Similar to Malaysia
Birel186
April Barcelona Test
bar555
bar555
FRONT WING SPAIN
Similar to Bahrain
clean air
clean air
Thanks for the photos.
Doesn't this approach lose to much down-force on corner entry?
Could it also be the reason for the loss of top speed?
Or is the problem the high nose all together?
ben_watkins
ben_watkins
All new rear wing at Turkey..
http://www.f1technical.net/development/154
BWP
Tripos Media Partners
#TriposMediaPartners
bar555
bar555
FRONT WING TURKEY
Similar to Spain
bar555
bar555
REAR WING - AUSTRALIA
REAR WING - MALAYSIA
REAR WING - BAHRAIN
No gurney tab
bar555
bar555
CHIMNEYS - AUSTRALIA
CHIMNEYS - MALAYSIA
CHIMNEYS - BAHRAIN
bar555
bar555
STEERING WHEEL - LAUNCH
STEERING WHEEL - image from Australian GP
TALK ( purple button ) = Radio , provides a link between driver and pit crew
DIFF INIT = Differential control which balances the wheels while entering a corner
DIFF MID = Differential control which balances the wheels in the apex
DIFF EXIT = Differential control which balances the wheels while exiting a corner
REV ( white button ) = Engine rpm control
PIT LIMITER ( yellow button ) = activates speed limiter inside pit lane
NEUTRAL ( green button ) = Neutral
+1 , +10 ( red buttons ) = Mode control , determines what data is shown in the display box
TORQUE / MIX = Governs the fuel/air mix
bar555
bar555
CHIMNEYS - SPAIN
CHIMNEYS - TURKEY
CHIMNEYS - MONACO
CHIMNEYS - CANADA
alex1015
alex1015
Brand new front wing for Britain. I thought that Honda had written off this year in favor of next.
This one dips far lower and the end plates have gained a new horizontal piece both on the inside and outside which is likely to guide the flow better.
Hope you don't mind me jumping into your thread bar555
Timstr
Timstr
Honda has stopped development for this year a while ago. What you see here and the next couple of races is the result of research done much earlier.
Moanlower
Honda came to Hockenheim with new barge boards and wheel fairings.
Edit: They have been using these fairings for a couple of races now. :roll:
Losers focus on winners, winners focus on winning.
legin_k
legin_k
does anyone have any idea what is in this picture?
http://www.racecar-engineering.com/imag ... d18261.JPG
some sort of ballast pod, maybe? or would it be testing related? i believe the picture was from the silverstone test.
full article at Racecar-Engineering: http://www.racecar-engineering.com/arti ... stone.html
