Aston Martin Red Bull Racing TAG Heuer RB14
M840TR
M840TR
315
Re: Aston Martin Red Bull Racing TAG Heuer RB14
godlameroso wrote:
12 Aug 2018, 05:56
Increase in surface area, potentially less turbulence under the car.
How does it increase surface area and reduce turbulence?
M840TR wrote:
12 Aug 2018, 07:52
godlameroso wrote:
12 Aug 2018, 05:56
Notice the changes. The area near the central section is slightly curved. It adds a small amout of surface area. It also smoothes the air flow along the central section.
jz11
jz11
19
if anything, then the shape of the new trailing edge would suggest reduction of the surface area immediately before it, not increase, that slight bow loses out to the straightened sharper bends it previously had in terms of the length of the edge, so it is probably more about the shape of the flow, not the surface area
jz11 wrote:
12 Aug 2018, 22:37
Fine if you only look at the trailing edge, but a diffuser is more than just a trailing edge.
M840TR
M840TR
315
godlameroso wrote:
12 Aug 2018, 13:28
M840TR wrote:
12 Aug 2018, 07:52
godlameroso wrote:
12 Aug 2018, 05:56
https://pbs.twimg.com/media/DgSPneJX0AAOJmm.jpg:large
You're right; there's more surface area in the central section. And it seems the trade off with the trailing edge is minuscule. They added tiny vortex generating fins underneath too.
Yurasyk
Yurasyk
M840TR wrote:
13 Aug 2018, 01:26
Those vortex generators have been there all the time. They are not visible above simply due to a different view angle.
carisi2k
Here is a question. How are those slots and gaps even legal. I know that just about every car has them but shouldn't they be illegal under the double diffuser rule?
carisi2k wrote:
13 Aug 2018, 07:05
The double diffuser rule forbids holes in the floor. Gurney tabs are perfectly allowed and have been around for I think a decade or so.
The double diffuser made use of a wording loop hole regarding the joining of the reference plane to the step plane. This loop hole has been removed.
The slotted gurney flaps on the top of the diffuser are in a space allowed by the rules. The top of the diffuser is 175mm above the reference plane and there must be no bodywork above 200mm above the reference plane. These flaps sit in the 25mm "gap".
F1NAC
170
Ferrari style mirrors, but it seems they just added additional housing around mirror that simulates Ferrari's set up.
Great details 8)
gandharva
252
F1NAC wrote:
22 Aug 2018, 18:03
https://pbs.twimg.com/media/DlNvXFEX4AIqwQG.jpg
I absolutely love this overly complex cooling air inlet. Because thats what the whole thing is meant to do. Now it also adds an improved rearwing inflow. Science - --- yeah! If it works we may see some new rearwing designs in the second half.
dren
227
I don't think it's a cooling air inlet.
Honda!
roon
roon
412
Always with the next level stuff, this team. Put a Merc or Ferrari engine in this chassis; we all know what the answer would be. When they aren't innovating something themselves, they're taking someone else's concept, and showing them what it will look like in two years...
dren wrote:
22 Aug 2018, 20:43
I think he's talking about the radiator inlet in that photo, its shape, how it interacts with the mirror pylons. Then making a separate point about how the mirror will interact with the rear wing.
The slot on the pylon, though. Something going on there.
Looks like they've just made the very last part of it twin element - perhaps the fairing was showing some flow seperation where the pylon joined without it.
