saviour stivala wrote: ↑11 Sep 2018, 11:13
If one goes by what one power unit manufacturer boss having been quoted as having said, namely that their power unit have now approached the 1000 BHP output, it means that sort of power output is the maximum they can now extract out of their power unit, which also means that the 1.6l turbo hybrid power output has reached 625bhp/l @ a maximum fuel flow rate of 100kg/h at 10500rpm, it also means that the ICE part of the power unit output has reached 839 bhp or 524 bhp/l, still at 100kg/h fuel flow rate at 10500 rpm.
I wouldn't give to much credit to what team principals say. They talk a lot of rubbish in the media as the day goes along.
I know about the "1000hp" claim but they never made it clear how exactly they meant it.
Wasn't this the same manufacturer which claimed at the end of last year, that they have surpassed 50% thermal efficiency of the PU on dyno runs?
Well there's already a problem, 50% thermal efficiency, isn't even near 1000hp. So one of the two statements must be wrong. Thing is though, 1000hp is just a stupid number where we have no clue how they got to it. Surpassing 50% efficiency is actually a technical achievment and means really the power which is send to the gearbox.
50% would mean somewhere in the 800-900hp region with the support of the MGU-K because they talked about the efficiency of the whole PU. The highest efficency is certainly reached in a normal race mode. Not in Quali mode. The article stated, that the difference between race and quali mode for the ICE can be up to 40hp because of the reduced pumping loses.
Well. 900-160+40=780hp.
So the numbers AMuS stated are perfectly reasonable for the ICE in Quali mode.
So, how they get the 1000hp number you may ask. Well, that's simple, combine all the possible outputs of the ICE and the MGU-K and the MGU-H and you quite certainly get a number higher than 1000hp. So everybody goes "Wow, so much power!", only problem is though, that's not the power send to the gearbox. That's the power the PU can put out as a System.
