2008 Jerez Test 22-25 July
Scotracer
Scotracer
Re: Jerez Test (22-24 July 2008)
Sawtooth-spike wrote:Image
BMW using low downforce 2009 ish spec and slicks.
Notice how wide the nose is again. Could this be something we will see next season?
That's the 2007 nose. So, I'm guessing that front wing is either their Monza wing from last year or a modified low-downforce wing from '07.
Powertrain Cooling Engineer
Conceptual
Conceptual
Would the F1.07 nosecone bolt right on the F1.08 chassis, or is that the F1.07 chassis???
Chris
Scotracer
Scotracer
Chris
Well, by the looks of the vortex generators on the sidepods, and other 2008 appendages I'm guessing its the 2008 chassis with 2007 front and rear wings.
As confirmation, in the chassis given by the teams official statement is "BMW Sauber F1.08-06". So, a 2008 chassis with 2006 parts.
modbaraban
modbaraban
Re: Jerez Test (22-25 July 2008)
gerhard
gerhard
it was a matter of time for that to happen...
CMSMJ1
CMSMJ1
That look even worse than the rest!
We always exepct Ferraris to look good I suppose..
IMPERATOR REX ANGLORUM
Sawtooth-spike
Ahhh but what ur missing is that this is only for massa to use in the wet as a keel.
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
timbo
timbo
113
Wow, in this pic we see how low is the bodywork around the rear axle!
I wonder if they try to run front wing more agressively, so far Ferrari was good through the sweepers, so stability may not be the primiry goal.
Scotracer
Scotracer
timbo wrote:Image
Yup - the introduction of the V8s really helped packaging. I just wonder how much of that will fatten out again when KERS is put back in.
yzfr7
yzfr7
Any reason for the distinctive fuel cap in Massa's car?
According to BMW's KERS, at least the sidepod area will be squared again... But that should be interesting, where the other teams will put the large/heavy batteries. As close as possible to the engine, for dynamics reason.
pax
modbaraban
modbaraban
yzfr7 wrote:Any reason for the distinctive fuel cap in Massa's car?
It's open. These caps are always very bright and distinctive on the inside so that you could easily notice that it'd opened or failed to close.
Harrelson
gerhard wrote:it was a matter of time for that to happen...
I think the top teams are running out of new ideas
Scotracer
Scotracer
Well it's a good idea -- it reduces yaw sensitivity of the rear-wing which is really useful on tracks with fast corners. Remember, they are copying Newey -- probably the best in the business.
ss.vamsikrishna
ss.vamsikrishna
Guys just check out the Mclaren's lap times by Kovy it is almost one second
faster than Ferrari of Kimi
Heikki Kovalainen (McLaren) 1:18.385
Kimi Raikkonen (Ferrari) 1:19:384
and both were on grooves ...
Suddenly Mclaren is very fast and unbeatable .they have updated their cars with new aeros constantly ...Looks like Mclaren will win this year :shock:
Scotracer
Scotracer
ss.vamsikrishna wrote:Guys just check out the Mclaren's lap times by Kovy it is almost one second
I wouldn't read into testing times too much. You don't know what they are testing -- qualifying or race setups, heavy fuel or running on fumes. I expect Mclaren to be fastest but only by a couple of tenths.
