What about software, you mentioned that in your "opinion" there is no TJI style pre-chamber, or any for that matter. That it was more to do with the in cylinder sensors than any fancy combustion tricks? Does the refinement of the sensors(hardware) have anything to do with the software side? Engine maps, or predictive algorithms to control knock and run the engine closer to the edge, are these limited by the resolution of the sensors?saviour stivala wrote: ↑10 Oct 2018, 08:10There is more French hardware than just batteries in FERRARI. In Honda I don’t know.
Your not imagining it, I saw it before it was deleted.godlameroso wrote: ↑10 Oct 2018, 22:58French horn intakes?
Maybe I'm imagining things but I could have sworn I made a post asking a question about pressure sensors, oh well.
Well, the battery cells are controlled through the software.saviour stivala wrote: ↑11 Oct 2018, 12:06What does software and pressure sensors got to do with French suppliers to FERRARI?.
Yes they are, everything is controlled by software. but do you mean that SAFT also suppllies the cotrol software to FERRARI? because that was what my post was about.turbof1 wrote: ↑11 Oct 2018, 12:42Well, the battery cells are controlled through the software.saviour stivala wrote: ↑11 Oct 2018, 12:06What does software and pressure sensors got to do with French suppliers to FERRARI?.
I am basically saying I don't really know, but my guess is the software is being developed by both Ferrari and SAFT and buried under a whole lot of NDA's.saviour stivala wrote: ↑11 Oct 2018, 12:59Yes they are, everything is controlled by software. but do you mean that SAFT also suppllies the cotrol software to FERRARI? because that was what my post was about.turbof1 wrote: ↑11 Oct 2018, 12:42Well, the battery cells are controlled through the software.saviour stivala wrote: ↑11 Oct 2018, 12:06What does software and pressure sensors got to do with French suppliers to FERRARI?.
As I said in my post of which was the one chosen now not to be allowed, it was all about blabbing about in responce to my post. but just in case there is a wish to go all over again what already had been discussed there is no problem from on this part.
I mentioned the same thing in the car thread last week. Seems weird.Phil wrote: ↑08 Oct 2018, 12:58On the missed apex broadcast, they are talking about that a button has gone missing on the Ferrari steering wheel since two races. Is this true? It's the first I've heard it being mentioned.
This would be my educated guess as well. SAFT can probably help them squeeze a little more performance and longevity out of the cells because of their IP.
I have no doubt that a there will be advice/recommendations from a hardware supplier as to the best operating and control of his hardware supplied.
At this level I honestly think it goes a bit deeper than that. I don't think it is like "here you go, these are our cells. Here's our advice on how to use them". Ferrari will have specific requests on shape, charge and discharge, on how to integrate them with their control unit software. That requires a strong partnership, not just a supply/demand contract.saviour stivala wrote: ↑11 Oct 2018, 13:34I have no doubt that a there will be advice/recommendations from a hardware supplier as to the best operating and control of his hardware supplied.
anthonyfa18 wrote: ↑11 Oct 2018, 13:24
At Suzuka, we also got a good look at the battery of the Japanese V6 which seems very compact, especially compared to the system fitted to the Ferrari SF71H. Top battery is Honda and lower is Ferrari
