here is the tweet showing both side of the Merc wheels.
https://twitter.com/AlbertFabrega/statu ... 6250705920
Yes but a stewards decision and be contested and then it goes to the FIA if memory serves!
The holes inside the hub area look to pass through into the cavity in the spokes. Take a look at the tweet i posted above.
Some people are going to be really unhappy about this!
Those holes are on every car wheel and are pretty much blocked off by the flange of the wheel when mounted though.Blaze1 wrote: ↑25 Oct 2018, 20:43The air comes from the 24 circumferential holes on the hub.PlatinumZealot wrote: ↑25 Oct 2018, 11:33We need to see the rear wheel hubs...
I dont see where the air comes from to go into the middle of the rim... The outer discharge point looks to shoot air tangentially. . Not sure if into the spokes or the barrel of the wheel... Need a side view.
Any more ideas?
https://cdn-2.motorsport.com/images/mgl ... -rim-1.jpg
Looks like a different material lines inside the wheel where the holes are. For insulation purposes of course. This thing is designed to prevent heat transfer to the centre part of the wheel.
https://pbs.twimg.com/media/DqUEXPIU4AAx3OR.jpg
EDIT:
Is it possible that part of the hub (the part with the 24 circumferential holes) can move inwards and outwards, either when the wheel is attached to the hub, thus revealing and locating the thermal management holes or while the wheel or while the wheel is attached based on temperature? (I don't know if the regs would allow this however.
