Formula Wrong wrote: ↑26 Nov 2018, 01:54
NathanOlder wrote: ↑25 Nov 2018, 22:19
If the car ends up like Perez in Budapest , the side he escaped from would have had a Halo bar running through the middle of it!
Wasn't that exactly
the scenario they showed in their presentation last year that a driver
can get out with the Halo? Car ending up upside down, slightly on its sidee?
Again, that video the car has no wheels, no suspesion, no wings, no PU, no fuel tank ect.
The airbox is not even touching the ground, So add the weight of a gearbox, Engine, hybrid system with heavy battery, fuel tank, rear wheels and rear suspension then the airbox will now sit on the ground (gap to escape reduced)
Now consider the side of the car on the ground (The drivers right hand side, or the side we cant see in that vid) add some suspension, tethered wheels to that side and its very likely the right hand side of the car will be propped up higher therefore rotating the car more upside down, and again reducing the gap to escape.
Then see how tricky it was to get out despite all these parts of the car missing, then you can see how a driver like Hulkenberg couldnt get out at all. I'm not quite sure how Hulkenbergs camera survived ? Is it something that has been reinforced to increase the gap to escape ? If so I never heard anything about it so it was done on the quiet
![Question :?:](./images/smilies/icon_question.gif)
