The secret Honda Hybrid test
In our earlier version of Technical Analysis of the RA619H, which Red Bull Racing will use in 2019, we could report that Honda has gone another route with the construction of its engine. For example, during the last three seasons in the MGU-H system, almost 1.3 mega joules per round of electricity were won. In collaboration with Brembo, the ability of the MGU-K has also been boosted. These independent items, which fall within the current power units, can be tested on street cars. Honda has a supercar in its arsenal, called the NSX and seems to have tested these systems last month on their own circuit, Suzuka. Honda tested the MGU-K and MGU-H from 2019 in a prototype NSX. This NSX was equipped with a current configuration engine, the 3.5L twin turbo V6. This has been brought to the level by engine control that gives the current RA918H engine performance. The temperatures of this 3.5 L V6 have been brought to the same level by Honda as the engine that is now in the Toro Rosso. With this configuration, Honda has done a test at Suzuka to see how much energy one could generate with the new MGU-K and MGU H systems. This NSX drove around 100 laps a day for three days on the Suzuka circuit, and the Units, the MGU-H and MGU-K generated more mega joules than initially intended. Indeed, this test confirmed that the hybrid systems of the Honda have a profit percentage compared to the current engine of nearly 6.5%. To make a calculation. With every 100 HP that these systems can deliver, Honda has already gained 6.5 extra for the 2019 version by optimizing these systems. In theory we talk about a higher percentage of profit, since this NSX V6 has a double turbo. Could this be a reason for Honda to share their turbo, like Mercedes, in the same way?
The effect on the dyno
Toyohiro Tanabe, F1 Technical Director at Honda, says the following: "Motor tests carried out on a car can not be carried out with FIA rules, at least not in the current configuration, but tests on test benches are possible. dyno in Milton Keynes so that it can be rotated with the gearbox There are already several tests, including a test with the bodywork including the gearbox We have the advantage that our facility in Milton Keynes is not far away from the Red Bull factory . " A very interesting note from Tanabe. The three dynos that Honda has were described by former McLaren Engineer Mark Priestley as Milton Keynes, Sakura and Austria. Further investigation has shown that it is not in Austria, but in Faenza at Toro Rosso. Honda has three independent teams that test the RA619H on the dynos. These tests are necessary to test the reliability, stability and operation with the gearbox. Tanabe's remark that the gearbox, engine and chassis have already become acquainted with each other concerns here in all probability an RB14 from the beginning of the year. This could be a car that could no longer be used. By this we mean the car with which Max Verstappen hit the wall in Monaco. Verstappen got a new car for the Sunday.
Honda, the Super Formula car
At the end of this year the current configuration of the Super Formula car, the Dallara SF14, disappears. This car is almost identical to the current Formula 1 car in terms of length, width and wheelbase. We are talking about a margin of a few inches here. The gossip that Honda wanted to test its power unit on a Super Formula car in Suzuka in 2015 was confirmed in that year by the project manager of Honda at the time, Yasuhisa Arai. Also the team with which this test would be carried out, Team Mugen, had already released a chassis and converted it to install the Honda RA615H. This modified chassis with associated parts is still at the factory at Team Mugen.
In Japan, the rumors have been rekindled about a test with Honda and this Super Formula car. Since this car, the Dallara SF14, is no longer competitive in its current form, because it will be replaced by the SF19, Honda suddenly has access to a chassis that is approved by the FIA and according to the regulations can be used as test vehicle. The product that Honda wants to set up here, the RA619H, has not yet officially participated in a Grand Prix. A 'loophole' in the regulations.
https://www.f1today.net/nl/nieuws/f1/24 ... motor-test
