I am quite sure that there is no such thing. There are probably a dozen drafts. The rules refer to the 1998 version. That I have read.Ogami musashi wrote:did you actually read the 2008 concord agreement?
Sure, he has something to do about Honda=)Ogami musashi wrote:brawn declared it was not still the case but he would like to take the role
Those two I've highlighted confuse me. I thought the front-wing would be limited to a maximum of 2 elements? Also, the 2nd highlighted point is that are you sure you mean 100cm? That's 1m above the reference plane!Ogami musashi wrote:Still bugging on the front wing regs.
Despite re-reading it many things appear not so clear:
-3.7.2, we thought it defines the pillar to connect the nose to the central part, but things are strange. First since the central part position is mandatory, why is that the section defined in 3.7.2 stop at 125mm above the Reference plane?
Why the reference section is an "horizontal section"?
It is strange also that those closed sections "must project vertically" to join the standard central part "below 125mm".
-From 250mm to 400mm from the center line, the chord will be limited
-It appears that between 400mm to 750mm from the center line no bodywork is concerned by the regulations
-The number of elements of the outer parts of the wing is not restricted as it seems.
-The end plates can't be higher than 100cm above the reference plane.
-3.7.2 and 3.7.8 seem to contradict a bit?
Considering the endplates can't be higher than 100Cm above the RP and that the standard part will be less than 125mm, but that 3.7.2 sections will be 125mm above i have difficulties to imagine the arrangement of the front wing.
any suggestions ?
That's what i think but why are they only defined till 125mm above RP?scarbs wrote:3.7.2 is for the front wing support pylons, there must be two of a limited area and thickness. I guess this is to prevent the front wing mounts becoming overgrown into turning vanes.
Well I'm guessing after that the FIA allows teams to have their own designs. So that's roughly 60mm of homologated pylon and then the rest is down to how high the teams what the nose.Ogami musashi wrote:That's what i think but why are they only defined till 125mm above RP?scarbs wrote:3.7.2 is for the front wing support pylons, there must be two of a limited area and thickness. I guess this is to prevent the front wing mounts becoming overgrown into turning vanes.
The diffuser has a Greater height (175mm vs 125mm). The length is also the same as now (330mm) it is simply moved aft (from wheel center line to 330mm aft) and the whole width of the diffuser is now allowed to be below 50mm above the RP.scarbs wrote:I have been looking at the new diffuser regs and compared them to the current ones. With the lower height (175mm) the diffuser exit area will be reduced some 20%. While the shorter length (330mm) reduces plan area by some 30% and volume by well over 60%.
What predictons can we make on this potential loss in area?
