Yes I recall that discussion. I’m afraid I don’t see any connection between the flow restriction, 4MJ ES to MGU-K and the state of charge.godlameroso wrote: ↑13 Dec 2018, 18:02You said the only SOC level was a 4MJ pool and that pool did not reset every lap. It was in the Ferrari power unit thread. I said there is a 4MJ limit from the ES to the MGU-K per lap, which resets on crossing the timing beam, and consists of one SOC. In addition to that, there is also the actual battery SOC which is independent of the SOC per lap.henry wrote: ↑12 Dec 2018, 23:22Can you remind me of the discussion? It’s quite likely that I might have disagreed with something you said because at the time I didn’t understand. My understanding of these power units is continually evolving, my knowledge of batteries and their management systems is limited. To be honest, given the limited amount of discussion on this forum, I don’t think I’m alone. So if you can point me at your “multiple VSOC” comments I’d be grateful, I’m sure it will advance my understanding.godlameroso wrote: ↑12 Dec 2018, 14:48
Didn't you dismiss the notion of multiple VSOC when debating me about when one can use 4MJ? Why the sudden change in opinion?
The 4MJ SOC lasts for the duration of the race it is never reset, as far as I know. The proposal I have made is that because the ES is not 100% efficient the SOC that is measured drifts down through the physical SOC. The physical SOC is consumed to replace the energy that goes in but doesn’t come out.
I am happy for anyone to show my reasoning is faulty.
