Teams aren’t allowed to change the Halo itself.
Take a look at Paolo Filisetti's other front view drawings from 2018, this is just the way he draws the halo and it should be noted that many of his drawings have areas which are exaggerated.
Hey Polite, maybe the article has been edited but where did you see it say anything about narrow body work?Polite wrote: ↑18 Jan 2019, 21:40https://it.motorsport.com/f1/news/ferra ... t/4325682/
claimed a narrow body work.
Speculation coming out of Ferrari has hinted that it may well have been tempted to go longer again this year. This is the result of a potentially longer transmission to move the engine away from the rear wheels – which has helped free up the possibility for a radical rear axle.
If Ferrari has gone down that route, then to help comply with the regulations (because the car's weight distribution is defined by the FIA) it will likely need to have to move its front wheels forward.
Doing that could then free up new ideas for some more aggressive sidepod solutions, which is an area where Ferrari has led the charge in recent seasons.
Not in that article, but in the rumors it s claimed to be very thin.Mr. Fahrenheit wrote: ↑19 Jan 2019, 17:17Hey Polite, maybe the article has been edited but where did you see it say anything about narrow body work?Polite wrote: ↑18 Jan 2019, 21:40https://it.motorsport.com/f1/news/ferra ... t/4325682/
It does state that - like Mercedes - the wind tunnel results suggest they've already reached the downforce levels of last year despite the changes to the front wing regulations.
Why do you think drag will be lower? I would think exactly the opposite. They banned wheel blowing and controlled much of the out wash from the wing so I imagine the tyre drag will increase a lot cause those two were mainly made to reduce it. Also the total surface of front/back wing will be bigger which can mean more total dragENGINE TUNER wrote: ↑23 Jan 2019, 06:05I expect the trend of increasing overhead cooling to continue, especially with the wider more effective/efficient/higher rear wing. That will allow even slimmer sidepod radiators, to further increase air over the diffuser.
Regarding the fuel tanks, I expect possibly the same size or even smaller fuel tanks than in 2018 regardless of the allowed increase in race fuel usage. Overall drag should be lower for the 2019 cars than for 2018, and thus fuel usage should also be lower.
If longer, it will only be for downforce generating purposes, but most probably with a lower rake.
Before answering I must admit that my knowledge of aerodynamics is very limited. I have zero knowledge of how the out wash front wing contributed to drag creation, or the blown front axle either.Big Mangalhit wrote: ↑23 Jan 2019, 10:33
