That's why DVRs exist!
anyone who has the sky f1 channel, has sky plus so although i wont be able to watch it live, I will record it.LM10 wrote: ↑21 Jan 2019, 15:18Plus, many people wouldn't really be able to watch the morning tests during week anyway because of work/study.bauc wrote: ↑21 Jan 2019, 15:06Its a smart move the cover the afternoon sessions. In the mornings the track is cold and most of the teams just do a test run and get back to the pits, more meaningful running is done in the afternoon so this might actually be a great broadcast by SkyF1. I just pray we don't see the snow again on the first days of testing following a flood on day 3NathanOlder wrote: ↑21 Jan 2019, 14:41They are showing live all the afternoon sesessions. From 1pm to 5pm. With a one hour show after its finished each day. So far its only confirmed for the first test 18th - 21st Feb. Sky Go on my tablet at work. SUPER!!
I’m sure you actually didn’t mean Mercedes?dans79 wrote: ↑21 Jan 2019, 17:53This is an interesting read, as i hadn't really thought about it this way.
https://www.autosport.com/f1/news/14110 ... 2019-trend
This, and the simplification of the front wing making it harder to seal high rake floors has the potential to be a real windfall for Mercedes. Maybe they will end up with an F2004 type of year!
No i mean Mercedes.LM10 wrote: ↑21 Jan 2019, 19:37I’m sure you actually didn’t mean Mercedes?dans79 wrote: ↑21 Jan 2019, 17:53This is an interesting read, as i hadn't really thought about it this way.
just nitpicking but 2014 to 16 exceeded the F2004 type Yeardans79 wrote: ↑21 Jan 2019, 17:53This is an interesting read, as i hadn't really thought about it this way.
Ok, I just misunderstood you. Thought you meant that Mercedes was going to have a hard time.dans79 wrote: ↑21 Jan 2019, 19:50No i mean Mercedes.LM10 wrote: ↑21 Jan 2019, 19:37I’m sure you actually didn’t mean Mercedes?dans79 wrote: ↑21 Jan 2019, 17:53This is an interesting read, as i hadn't really thought about it this way.
- Mercedes already has the longest wheelbase of the top 3 teams, so they will be the most familiar with the issues associated with it.
- Mercedes runs the lowest rake as well, so they should have fewer issues sealing the floor than those who run higher rake.
I was thinking F2004 as Schumacher won 13 of 18 races that year, that's the best winning percentage (72.2%) ever for a single season. The years/cars you mentioned have more evenly matched driver pairings. Unless something drastically changes with Bottas, I think 2019 will be like Ferrari in 2004.
Very optimistic.dans79 wrote: ↑21 Jan 2019, 20:16I was thinking F2004 as Schumacher won 13 of 18 races that year, that's the best winning percentage (72.2%) ever for a single season. The years/cars you mentioned have more evenly matched driver pairings. Unless something drastically changes with Bottas, I think 2019 will be like Ferrari in 2004.
it is the banter thread!
Unless point C is there to prevent the teams to put it "hidden" beneath the driver seat4.4 Ballast:
Ballast can be used provided it is secured in such a way that tools are required for its removal.
It must be possible to fix seals if deemed necessary by the FIA technical delegate.
Ballast designated for the sole purpose of achieving the driver weight specified in Article 4.6.2 must:
a) Be entirely located to the car between the front and rear extent of the cockpit entry template.
b) Be attached securely to the survival cell and sealed by the FIA.
c) Be clearly identified.
A nominal such weight of 10kg should be present for the impact test described in Article 16.3.
