MarioF1 - that would be interesting to see. Here are my interpretations of the rules. All have been superimposed on a BMW F1.08 as the fundamental dimensions of the car do not change.
The think blue line is effective the start of the banned area for bodywork. My understanding is that you can have bodywork before this as per 3.11.1.
Rule 3.8.4 controls everything upto 450mm ahead of the cockpit entry template. There can be no apertures and fins here by that rule
Rule 3.8.6 is the one I referred to with regard to bodywork enclosing the impact absorbing structure. There can be no closed sections. Not quite sure exactly what this means but I am guessing it prevents bodywork from the sidepods extending and forming closed structure (pod fins etc.). This may also limit bargeboards as well - the bargeboards are attached to the bottom edge of the sidepod so you could argue that there is a closed structure there in a particular longitudonal plane.
Saying that you can attach the board differently I suspect.
The purple line is my view of how a bargebard may look.
