The unfortunate thing here is, everything you mention regarding Honda's PU is completely devoid of genuine fact and is totally baseless. Actually sounds like Cyril is talking here.atanatizante wrote: ↑14 Feb 2019, 00:58That! That`s the reason they have so small sidepods air intakes! And that leads obviously to a higher CoG of the car not the engine, which is far worse, btw ...
And that`s not the weakest point in Honda`s PU armour. Maybe this year they reached almost the same max. power output both in the race and in qualy but certainly they are behind Ferrari and Merc in combustion efficiency hence requires more fuel than both ICE`s above mentioned.
With 2 tenths per lap gain for every 5kg of fuel - as Andy Cowell said - this means Merc acknowledged that the gain Ferrari`s ICE was doing last year was mainly due to a better fuel combustion process (coming out from an exclusive technology provided by Mahle and a renowned scientist, had I`m not wrong) and acted this year accordingly ...
This high fuel consumption statement... where are you getting this from? And wherever it was, I'm hoping you confirmed it was fact.. I don't recall this being a particular issue at all last year? Not comparatively to Renault anyway.
Honda have also only ever run a cooling package that relies on sidepod radiators since they re-entered F1, IF the radiators are 100% stacked above the PU this year as we are theorising, it is an entirely new design that was decided on with RBR, so I would only assume they have found some benefit in doing it this way, so not sure why that's indicative of a "chink in Honda's armour"? Maybe we should cross examine with the STR14, as last year they used a twin rad setup in both sidepods.
