2019 performance speculation
the EDGE
the EDGE
67
Re: 2019 performance speculation
f1316 wrote:
12 Feb 2019, 16:08
If FIA wanted cars to run with enough fuel to avoid lift and coast, why not specify that you *must* (as opposed to ‘you are allowed to’) have a fuel tank capable of contraining 110kgs of fuel?
Surely that’s a quantifiable, measurable compliance test which is easy to mandate?
Teams could obviously still choose to short fuel but it’s at least once they’ve made the compromises necessary to fit that size of tank, they’re more likely to use it than if they have the option to fit a smaller one altogether, taking the performance benefits in terms of packaging in full knowledge that it will require lift and coast. In other words, it weights the decision more in favour of having enough fuel to run flat out.
Part of the goal of F1 is to push limits of design, and build fuel efficient, greener engines. Following your concept and the concepts that followed, having a fuel eficient engine would become a handicap because you would design your car to burn more fuel than necessary to burn up the excess weight
LM10
LM10
121
roon wrote:
16 Feb 2019, 21:23
Merc's sixth consecutive WDC.
A still-winnowing Ferrari with a bigger gap to second than in '18, losing more points to RB.
RB with a test-bed engine for another third place year.
Fourth goes Renault, Haas, or Racing Point.
Merc's main competitors in Ferrari and RB are both contending with major changes (driver lineup for both, PU supplier change for RB). It's Merc's season to lose. Expect more masterful sandbagging with a comfortable late season walk-away.
Why on earth would they go for sandbagging? :wtf:
In 2018 Ferrari destroyed their own season eventually. The reason was not Mercedes stopping sandbagging.
roon
roon
412
LM10 wrote:
16 Feb 2019, 21:36
To avoid rules changes and calls for parity.
f1316
f1316
82
the EDGE wrote:
16 Feb 2019, 21:33
f1316 wrote:
12 Feb 2019, 16:08
I know what you’re saying and I largely agree. But what I’m saying is that just allowing the larger tanks won’t solve the problem the FIA were intending to solve - if they actually want to get rid of lift and coast then you actually have to regulate in such a way that provokes that. Perhaps, to incentivise more fuel efficiency, you could be allowed a smaller tank by passing some kind of verifiable fuel economy test (e.g. something like running the car on a rolling road as you might with a road car) to show you can run flat out with that amount of fuel for the required distance.
My opinion is and always will be that formula one was better as a series of sprints - and that this is naturally removed any (significant) need for tyre or fuel saving - but doesn’t seem like that’s ever going to happen again.
the EDGE
the EDGE
67
So bring back re-fueling & make smaller tanks, lighter cars that don’t require setting up for such a wide weight change during the race, resilient tyres ... I’m all for that, I never wanted F1 to move away from it
Gaz.
Gaz.
roon wrote:
16 Feb 2019, 21:55
LM10 wrote:
16 Feb 2019, 21:36
Did the FIA release two sets of rules for F1, a Merc rulebook and an Everyone Else rulebook? No, so there's already parity.
Forza Jules
If they lost 1.5 seconds, then it means that at worst the cars will be as fast as they were in 2017, in effect a soft reset.
Jolle
Jolle
133
the EDGE wrote:
17 Feb 2019, 00:05
In the refueling era fuel contributed around 10-15% of the total mass of the car, same as now.
With a 70 liter tank and re-fueling the cars could be made 50kg lighter pretty easily. Maybe off topic but the driver ballast idea was a good one. F1 cars can rely on less aero if they're made lighter. If F1 cars were 150kg lighter you could greatly restrict aero without affecting lap times too much. The cars back in 2004 had horrible aerodynamics compared to today, but they were 2/3rds the weight.
After the first day of testing almost nothing can be said. Regardless, I'll give my 1st day verdict.
The field has gotten closer not further apart. The teams converging pretty much on the jet fighter side pods, curved diffusers, and generally shrink wrapping the car. Only question mark is Williams, so far I can see the field covered by 2 seconds nose to tail.
Big improvement from McLaren over last year. This year's car already faster than last year's. Much more reliable much more planted, sector 3 was ok so still some work to do.
FrukostScones
162
Ferrari
Merc
RedBull
McLaren
Sauber
HAAS
TR
Renault
Force India
Williams
FrukostScones wrote:
18 Feb 2019, 20:37
Ferrari
Merc
RedBull
McLaren
Sauber
HAAS
TR
Renault
Force India
Williams
Ferrari is definitely out in front, Mercedes is definitely faster than they're letting on, probably very close between them. Red Bull looks very planted, but I can't say for sure where they stack up. Renault is probably a bit behind McLaren, but too close to really call. The picture will get clearer as the days go on.
FrukostScones
162
Sure, Merc is maybe fadster then Ferrari and Rb maybe worse... fun prediction and adjusting, until season kicks off 15th March.
shryr
shryr
1. Ferrari
2. Mercedes
3. Red Bull
4. Renault
5. Alfa Romeo
6. McLaren
7. Haas
8. Racing Point
9. Toro Rosso
10. Williams
sriraj1031
sriraj1031
-1
18 Feb 2019, 20:37
Ferrari
Merc
RedBull
McLaren
Sauber
HAAS
TR
Renault
Force India
Williams
Mercedes par with Ferrari
Red bull
Sauber
McLaren
Haas
Renault
Racing point
TR
Williams
