Scuderia Ferrari SF90
Re: Scuderia Ferrari SF90
Via @kasta32
jumpingfish
53
Does this element create a certain imbalance in the airflow for the left and right side of the car?
McMrocks
McMrocks
32
Probably some testing equipment. Maybe even the antenna.
Ferrari used to have skyscrapers on their T-cam:
Tzk
Tzk
34
As there’s flowiz on the frontwing, this is either a sensor or a camera filming the front of the car.
f1316
f1316
80
f1316 wrote:
23 Feb 2019, 01:31
gandharva wrote:
22 Feb 2019, 15:49
f1316 wrote:
22 Feb 2019, 12:45
So here’s the direct comparison with DRS for both:
This is no direct comparison! DRS on RedBull was open! If you have some basic understanding of this cars you cannot use this as a baseline for comparison.
Eeeeer... it’s open on both cars... :roll:
Ok well you’ve rated me negatively and still seem to think it’s closed on the Ferrari - I guess the gifs aren’t working for you or something.
Observe:
Might nice if in future you don’t jump to the conclusion that the other person is stupid and doesn’t have ‘a basic understanding’ (when they’ve gone to the effort of posting the comparison).
gandharva
252
f1316 wrote:
23 Feb 2019, 01:31
gandharva wrote:
22 Feb 2019, 15:49
f1316 wrote:
22 Feb 2019, 12:45
Are you blind? This one was used for that comparison shots that go around in the forums:
And then downwoting my post on top of it. Welcome to my ignore list.
henry
324
Cedo wrote:
23 Feb 2019, 01:16
Here is Marc Priestley explaination to someone asking him what going on with the Ferrari pitching stuff..
https://postimages.org/
The first part of this
“The Ferrari more softly sprung to encourage weight transfer”
Is wrong on two counts.
Firstly the “transfer” of tyre load from front to rear is not dependant on the suspension stiffness. They could run no suspension at all and the exact same change would happen. What the stiffness does is affect the amount of movement and how quickly that movement happens. The first is down to the springs and the second the damping elements. So a car with soft suspension moves more in response to the exact same forces experienced by a more stiffly sprung car.
Secondly it’s not “weight” that gets transferred it’s load. Load is the sum of the downward forces acting on the axles. The weight of a car is one of those forces. It is the mass of the car being accelerated downwards by gravity.
From the point of view of the SF90 what’s interesting is the amount of movement, suggesting soft springs, and the timing of the movement which suggests the “damping” is responding to something other than just simple movement. People in earlier posts have suggested some possible theories on this.
One effect of holding the car down at the beginning of braking in this way would be to reduce the load transfer by keeping the centre of gravity down, essentially making the car perform as low rake before transitioning to high rake just before corner entry. I don’t know why this would help.
Here’s an explanation of my understanding. The forces on the axles get redistributed by simple physics.
When the car brakes a rearward force is generated at the tyre/road surface boundary. This is matched by a force acting through the CoG. This pair of forces tries to tip the car forward and is resisted by an increase in force on the front axle and an equal reduction in force on the rear axle (the load transfer). The magnitude of the load transfer is determined by the ratio of the height of the CoG above the road surface to the wheelbase.
For a car mass 800 kg, CoG height 36cm, wheelbase 360cm, braking at 4g. The braking force is 32000N and the force transfer 3200N. Which is 320kgf or 700lbf.
LM10
LM10
121
henry wrote:
23 Feb 2019, 12:29
Cedo wrote:
23 Feb 2019, 01:16
What exactly do you mean with the timing of the movement? And what would the damping respond to other than simple movement?
Godius
186
gandharva wrote:
23 Feb 2019, 11:22
f1316 wrote:
23 Feb 2019, 01:31
gandharva wrote:
22 Feb 2019, 15:49
https://media.giphy.com/media/1yTgcCeZM ... source.gif
There is some miscommunication going on here.
He posted the Ferrari/RBR DRS comparison via a mp4 link but in a [/img] tag, it does not show up on the forum board. When you quote his comparison post you can see the actual link:
Ferrari: https://i.imgur.com/z8BkP8W.mp4
RBR: http://i.picpar.com/2zhd.gif
Godius wrote:
23 Feb 2019, 13:10
gandharva wrote:
23 Feb 2019, 11:22
f1316 wrote:
23 Feb 2019, 01:31
Ferrari still moves the same DRS or not.
f1316
f1316
80
gandharva wrote:
23 Feb 2019, 11:22
f1316 wrote:
23 Feb 2019, 01:31
gandharva wrote:
22 Feb 2019, 15:49
I mean... I *just* showed you the screenshot with the drs open in the comparison that I posted (not the ‘shots that go around the forum’ - what I posted).
Really very odd behaviour.
Edit: the mp4 shows up for me (see the screenshot I posted) but I did give you the benefit of the doubt of saying perhaps you couldn’t see it. Well anyway, it’s all very unimportant so let’s just forget about it.
JondoIramat
JondoIramat
henry wrote:
23 Feb 2019, 12:29
Cedo wrote:
23 Feb 2019, 01:16
Did you take into account the wheel radius and possible uphill or downhill movement while braking?
henry
324
LM10 wrote:
23 Feb 2019, 13:04
henry wrote:
23 Feb 2019, 12:29
Cedo wrote:
23 Feb 2019, 01:16
By timing I mean how fast or slow the suspension movement is, and in the case of the SF90 how it is displaced in time from the initiating event.
Obviously the damping has to respond to movement, the regulations require it, I was struggling to express the more complex possibilities involved in the time shifting of such events. Maybe I could have found better wording.
henry
324
JondoIramat wrote:
23 Feb 2019, 14:31
henry wrote:
23 Feb 2019, 12:29
Cedo wrote:
23 Feb 2019, 01:16
In the simple case of load transfer under braking I don’t think wheel radius or slope has a part to play. The forces involved are either parallel to the road surface or perpendicular to it.
Am I wrong?
Zynerji
110
It's just damper settings.
When I sim raced at Simdy 500, the whole trick was to get the nose to squat into the first/3rd turn, and not fully recover until after exiting 2/4. The front end grip was very necessary, and fast.
It was all front/ rear 3rd spring bound and rebound settings.
