McLaren MCL34
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL34
What you’re saying is that 0.5 sec behind last years ferrari (essentially) is a bad thing?
I’m delighted with what I’m seeing. Development is being added which means they’re happy with the base. Car looks stable. Great in high speed. So far so good!
mwillems
44
Re: McLaren MCL34
According to Zak Brown when being interviewed on Sky, the Renault PU delivered exactly what Renault said it would. He actually went on to say we have the power we need...
I look forward to seeing how close we are to the front after qualifying tomorrow. This update could bring decent time. There is also still a lot of room for development on the car. Interesting to see that Red Bull and Mercedes now also have the slots behind the Halo to release some of the air from the sidepods and energise the flow around the car. I'm not sure how much time this would bring but I'd like to think it isn't a big job to implement and might be a quick win.
-Bandit
gtm1260
gtm1260
Re: McLaren MCL34
Flow-Viz on the bargeboard updates today in FP1
trinidefender
trinidefender
317
Re: McLaren MCL34
Does this car even have any under nose turning vanes? I haven't seen any pictures of any since the car was launched.
f1rules
f1rules
594
Re: McLaren MCL34
nicolas carpentiers
@NicolasF1i
20m20 minutes ago
trinidefender
trinidefender
317
Re: McLaren MCL34
Another difference is the metal vertical parts that close the gap between the non adjustable outer section and the adjustable inner section are placed differently where the metal part meets the adjustable inner section of the wing.
The wing in the lower picture will be able to be adjusted upwards far more than in the top picture before there is any separation of the two vertical metal tabs.
It seems that this was done to create more downforce as maybe they were running out of adjustment on their front wing previously.
Re: McLaren MCL34
f1rules wrote:
29 Mar 2019, 17:37
nicolas carpentiers
@NicolasF1i
20m20 minutes ago
https://pbs.twimg.com/media/D21dy6NWoAAaPg1.jpg
Wow the driver seat has a drill holder!
Re: McLaren MCL34
the rake is back!
Tzk
Tzk
34
Re: McLaren MCL34
diffuser wrote:
30 Mar 2019, 00:19
the rake is back!
Uhm, was it gone? I didn't pay attention in testing and AUS...
trinidefender
trinidefender
317
Re: McLaren MCL34
Tzk wrote:
30 Mar 2019, 00:28
diffuser wrote:
30 Mar 2019, 00:19
the rake is back!
Don't think so. People just thought so because the release renders showed very little rake.
SmallSoldier
SmallSoldier
479
Re: McLaren MCL34
trinidefender wrote:
Tzk wrote:
30 Mar 2019, 00:28
diffuser wrote:
30 Mar 2019, 00:19
the rake is back!
Yes, there was an analysis by AMuS if I’m not wrong where they analyzed the rake of the cars during week one of testing and even then, the Mclaren was in the middle in terms of rake compared to the rest of the cars... Although lower rake and larger wheelbase compared to last year.
the EDGE
the EDGE
67
Re: McLaren MCL34
SmallSoldier wrote:
30 Mar 2019, 04:04
Tzk wrote:
30 Mar 2019, 00:28
AMuS just another sports magazine... just cos they say it, doesn’t mean it’s true
DiogoBrand
73
Re: McLaren MCL34
That also depends on what you look at. If the wheelbase is longer, it's unlikely that they'll be able to seal the floor if they use the same rake angle since same angle plus longer wheelbase equals higher diffuser. It's more likely that they reduced the angle but kept the height of the diffuser more or less the same.
Re: McLaren MCL34
No opening on top off sidepod for cooling... Must be confident with cooling solutions...
mwillems
44
Re: McLaren MCL34
mclaren111 wrote:
30 Mar 2019, 09:36
https://cdn-3.motorsport.com/images/mgl ... oard-1.jpg
I've seen in a couple of analyses that this also energises the air around the sidepod whilst allowing for a tighter back end, However, in the red bull thread they say it is just cooling.
So is it just cooling? Ferrari have had this since Barcelona and to increase cooling in Aus they opened up the back end a bit.
-Bandit
