Cheap power is not a problem. Just a simple block with a huge turbo and you've got it. The thought process of rule making go in the opposite direction. They start with an objective in HP they want and come up with a challenging set of rules for manufacturers to meet that goal.Zynerji wrote: ↑01 Apr 2019, 22:17Why does an activity that involves racing bespoke cars around a track require anything as advanced and complicated as the current power units?mzso wrote: ↑01 Apr 2019, 14:48Why not go back to steam engines if we like obsolescent technology that much?Zynerji wrote: ↑01 Apr 2019, 06:06Can we just get 3.2L V12s with a single centrifugal supercharger (max boost @18000rpm), direct injection, and TJI?
Should get us 1500 hp with midrange torque and screaming noise as well as being cheap enough to run a new one every weekend.
And no possible electrocutions...![]()
If you could get more power from a simpler arrangement, I'd vote for that as well.
And don't forget. A large part of the fan base wants simple engines that do not cause in race failures, or pre race penalties. And they want them loud.
Can steam engines compete on power to weight ratios against a supercharged ICE?
I thought not...
As for why these very complicated PU's: efficiency of investment. Of course, a 3.0l V12 could reach well up to 1000hp but the only use for all the tech developed for a engine like that is to no use other then F1. Apart from the real exotics, even Ferrari, McLaren, Porsche and Mercedes are all downsizing with turbo's. The engine recovery tech, the combustion chambers and injecton methods will see it's way to production engines pretty soon, just not always at the places you expect them... 50% efficiency it not something you going to find in a hypercar, but in a city car, or truck, of bus.
Daimler, Renault and FiatChrysler (and Mahler of course) can now use their billions they invested in F1 use for their production engines.
