McLaren MCL34
Re: McLaren MCL34
The boomerang is reshaped beyond what is needed to match the floor mods.
Peter1919
Peter1919
Re: McLaren MCL34
The detail in the bargeboard area now is immense, just think back to early 2017 when the McLaren was so basic in this area
https://www.motorsport.com/f1/photos/mc ... /12821470/
SmallSoldier
SmallSoldier
486
Re: McLaren MCL34
That was something that I always wondered... How simplistic compared to the rest of the teams that area was.
One thing that I still don’t fully understand is why Mclaren seems to not want to use an “S-Duct”... Seems to be a solution all other teams find that adds performance and was interesting that neither last year’s car nor the MCL34 use one.
Re: McLaren MCL34
SmallSoldier wrote:
05 Apr 2019, 23:28
Me too on S-duct ...think it disappeared from 2017 to 2018? Maybe in anticipation for the new nose?
M840TR
M840TR
315
Re: McLaren MCL34
SmallSoldier wrote:
05 Apr 2019, 23:28
That was removed to use the central duct for powering the cape instead.
Re: McLaren MCL34
High rake in testing...
Re: McLaren MCL34
SmallSoldier wrote:
05 Apr 2019, 18:04
mclaren111 wrote:Motorsport.com
https://cdn-1.motorsport.com/images/mgl ... oard-1.jpg
McLaren introduced a new bargeboard arrangement in Bahrain and seemingly unlocked some of the untapped potential of the MCL34. The new design’s forward footplate shape was revised quite significantly (red arrow and dotted line), while a series of variously sized vertical fins (white arrow) that we’ve seen others use for some time now were added. These make up a sort of pre-bargeboard arrangement and help to guide the airflow in that region. Behind the bargeboard the splitter (blue arrow) has also been extended in order that it interacts more effectively with the floor behind.
Edit: No reference to change of the top section... :o
The top section / boomerang had to be cut to match the cut on the floor
Agree... But no mention of it in this analysis... :?
Ground Effect
Ground Effect
Re: McLaren MCL34
mclaren111 wrote:
06 Apr 2019, 12:04
https://www.f1-fansite.com/wp-content/u ... 567688.jpg
Image doesn't seem to be loading
Re: McLaren MCL34
Ground Effect wrote:
06 Apr 2019, 12:21
mclaren111 wrote:
06 Apr 2019, 12:04
Espen84
Espen84
Re: McLaren MCL34
https://www.motorsportweek.com/news/id/22257
What does this mean? Does he mean the McLaren could be stronger at the front than the rear, or the other way around? Or is it something else?
M840TR
M840TR
315
Re: McLaren MCL34
Espen84 wrote:
06 Apr 2019, 18:36
The opposite. It struggles with understeer which wasn't exposed as much in Bahrain since it's rear limited, as in corners require a planted rear-end. The next two tracks' long straights should suit the car though since that's where they make up most of the lap-time; and maybe they'll find a way around - like working the front tyres better - to mitigate the issue like Ferrari.
Ground Effect
Ground Effect
Re: McLaren MCL34
M840TR wrote:
06 Apr 2019, 18:53
Espen84 wrote:
06 Apr 2019, 18:36
So what are the solutions to an understeery car?
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL34
More front end downforce
Ground Effect
Ground Effect
Re: McLaren MCL34
101FlyingDutchman wrote:
06 Apr 2019, 20:05
So, basically, it's a bigger challenge to add front end downforce due to the new front wings?
the EDGE
the EDGE
68
Re: McLaren MCL34
06 Apr 2019, 20:51
06 Apr 2019, 20:05
It’s not just about more front end down force
For a start, that would only really work in medium to high speed corners, at low speed aero works less efficiently and understeer is cured by more by mechanical grip
Second, car set-up is all about balance. You also have to think about how downforce changes from low to high speeds, what increases downforce at low speeds to reduce understeer could induce oversteer at higher speeds on the same track. You also have to increase front end downforce without it upsetting the flow of air around the car and stealing rear downforce
Finally, downforce has to be a net gain when taking the drag they create into account, so solutions need to efficient as well as effective
