[MVRC] Mantium Virtual Racecar Challenge 2018
Alonso Fan
Re: [MVRC] Mantium Virtual Racecar Challenge 2018
Thanks. Good suggestion. I had a very brief encounter with fusion 360 when it started out as inventor fusion. At the time I didn't know how to model on parametric cad so I left it for sketchup. That's until I went to uni and learned solidworks.
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
CAEdevice
50
Hi, a new realese of the wheels is ready, the deformation and contact area are much more realistic (despite we need a compromise with averaged values, considering that the load on the wheels changes with speed and acceleration).
Is there any news/request about the brakes ducts and about the sospensions? The section of the suspension arms is not parallel to the ground, there is a small angle (around 4°) in order to make the section neutral in real flow conditions. I also used slightly "fatter" section than allowed by F1 rules in order to adapt to the different angles of the flow.
machin
162
Are the suspensions in FreeCAD format? If so yes, please E-mail then to me...
Also, I am struggling to make a simple but good looking crash helmet for the driver... do you (or anyone else) have one? We’re not looking for anything too detailed...
Thanks,
CAEdevice
50
machin wrote:
09 Apr 2019, 12:19
Thanks,
No sorry, I used Solidworks.
I can model the helmet, but I can't find the general dimensions.
LVDH
46
We should be able to import the STEP into FreeCAD.
machin
162
I'll take some measurements of my helmet tonight.
hollus
Wouldn't the helmet in the Perrinn car be enough?
Rivals, not enemies. (Now paraphrased from A. Newey).
CAEdevice
50
hollus wrote:
09 Apr 2019, 16:56
Yes, great idea. I have the F1 Perrinn 2016 Helmet somewhere, in STEP format.
machin
162
Yes, thanks Hollus for the suggestion and Matteo for the file... that Perrin Helmet is pretty good: nice shape without being overly detailed.
etsmc
etsmc
sorry but another question for @LVDH regarding post-processing.
I have my on monitoring surfaces that post-processing is producing images of the streamlines which is awesome but it is hard to tell which monitoring surface is producing what streamlines.
Say I have 2 monitoring surfaces close to each other under the floor they look near identical, does the filename correspond to something or is it possible to get the name of the monitoring surface on the image somewhere?
I have been playing with a simple test car with rules similar to the old championship and getting a cl/cd of around 2 so still going to lag behind for a while I think...
looking forward to the supplied parts.
LVDH
46
etsmc wrote:
10 Apr 2019, 05:52
Right now, I am afraid the file names are somewhat obfuscated. I was always wondering about also creating an image with all streamlines together but not coloring them by velocity but rather giving each set of streams a discrete color. What do you think about that?
etsmc
etsmc
LVDH wrote:
10 Apr 2019, 16:36
I like that idea.
Is it hard to do as I wouldn't want something as trivial as this to take time away from the main development and pull focus from the championship?
CAEdevice
50
Sorry for the delay!
https://eternitywall.it/m/7c8ec26ac039a ... 48a4c41c80
MVRC 2018 results have been included into the Blockchain.
Congratulations to Variante!
machin
162
CAEdevice wrote:
14 Apr 2019, 11:59
MVRC 2018 results have been included into the Blockchain,
8)
Just a little update for you guys as we've been a little quiet over the past couple of weeks: the standard parts and legality volumes are pretty much complete now, and we are in the process of building our own test car (currently about 90% complete), and finalising Mantium Flow updates. Our plan is to use the test car over the weekend to validate that the rules are workable, and that the Mantium Flow changes work as planned....
Maybe if Andre is happy I will post a picture of the MVRC Test Car in a the next day or so....
CAEdevice
50
Thanks for the update!
