![Applause =D>](./images/smilies/icon_clap.gif)
The Nano paint to dispose of heat better.
Source automoto.it
The Barcelona update might still not be a direct reaction to the issues they're having. This is probably just a normal long planned evolution.Chuckjr wrote: ↑04 May 2019, 10:29Well this is puzzling. If their issue is not aero, why big aero upgrades? Isn't it suspension that needs attention? I thought Vettel said it wasn't an aero problem.![]()
http://www.gptoday.com/full_story/view/ ... r_Ferrari/
Do you think they’ll stop upgrading the car just because their current issue is not aero related?Chuckjr wrote: ↑04 May 2019, 10:29Well this is puzzling. If their issue is not aero, why big aero upgrades? Isn't it suspension that needs attention? I thought Vettel said it wasn't an aero problem.![]()
When there s a tyre problem you fix the whole car, more downforce better suspension everything. Still the primary cause is not aeroChuckjr wrote: ↑04 May 2019, 10:29Well this is puzzling. If their issue is not aero, why big aero upgrades? Isn't it suspension that needs attention? I thought Vettel said it wasn't an aero problem.![]()
Maybe the new specification solved the problem with reliability.
More power allows more drag and this equals more downforce....Carl Mccoy wrote: ↑07 May 2019, 17:42Maybe the new specification solved the problem with reliability.
But in Barcelona even a much more powerful engine will not make you catch up with Mercedes.
Of course you'd need to be able to add this downforce.mmred wrote: ↑07 May 2019, 21:04More power allows more drag and this equals more downforce....Carl Mccoy wrote: ↑07 May 2019, 17:42Maybe the new specification solved the problem with reliability.
The engines will be rotated and they will end up running about 7GP each. Spec 1 will surely be used in Monaco, on Fridays and possibly Singapore. So no, they won't have too extend their life by 2 races. If anything maybe by one, if they use spec 2 in a less demanding GP after they introduce spec 3. Anyway, if it is true that Ferrari have engine reliability problems, it makes more sense to change it now rather than in Canada.wesley123 wrote: ↑08 May 2019, 11:40Of course you'd need to be able to add this downforce.mmred wrote: ↑07 May 2019, 21:04More power allows more drag and this equals more downforce....Carl Mccoy wrote: ↑07 May 2019, 17:42
Outside of that, it isn't that easy in an energy-limited formula. They need to extend the life for the other engines with 2 races overall now, this might lead to grid penalties late in the season.
I'm pretty perplexed with this decision especially because of how hard it is to pass on this track. Unless they're confident in a front row lockout I don't see how a more powerful/reliably powerful engine would give them more passing opportunities if they don't qualify very well. Last sector of Barcelona takes away so much of the flow of the circuit in my opinion.Carl Mccoy wrote: ↑07 May 2019, 17:42Maybe the new specification solved the problem with reliability.
they can use them just on fridays tooPartymood wrote: ↑08 May 2019, 14:39The engines will be rotated and they will end up running about 7GP each. Spec 1 will surely be used in Monaco, on Fridays and possibly Singapore. So no, they won't have too extend their life by 2 races. If anything maybe by one, if they use spec 2 in a less demanding GP after they introduce spec 3. Anyway, if it is true that Ferrari have engine reliability problems, it makes more sense to change it now rather than in Canada.
