2019 Mclaren F1 Team - Renault
Ground Effect
Ground Effect
Re: 2019 Mclaren F1 Team - Renault
dr_cooke wrote:
14 May 2019, 11:28
Ground Effect wrote:
14 May 2019, 10:54
Wish we could get tyre information
With tyres:
http://directo.soymotor.com/
Thanks =D>
fouad1979
fouad1979
Mercedes are miles ahead but i hope we can find some couples of tenths during this test the low speed corners are our nightmare
_cerber1
261
fouad1979
fouad1979
i guess nothing new to test there area in this car which is average comparing to mercedes and Redbull like bargeboards mirrors and floor design we need big big upgrades to be near the top
BrunoH
BrunoH
they should ban the 3 top teams from in season testing to see if the other could catch up.....
flexcon
flexcon
Just me or is that front wing gone ever further in the same direction as Ferrari - going for in wash?
Looked to me that Ferrari, Torro Rosso and Alfa would change to the direction of Merc and Redbull.
NiyolHuayra
NiyolHuayra
flexcon wrote:
14 May 2019, 13:21
This one was used in quali and race
Dipesh1995
Dipesh1995
104
James key pretty much confirmed that the current solution isn't the optimal one and that the Red Bull version is better in his interview with chandhok.
Ideally, you want to load the inboard part of the wing as little as you can get away with whilst obtaining a Y250 vortex of sufficient strength. This is because the more you load the inboard part of the wing, the greater the loss of dynamic pressure within its wake as you take more energy out of the flow which then hurts the underfloor/bargeboards performance.
M840TR
M840TR
315
flexcon wrote:
14 May 2019, 13:21
Outwash.
_cerber1
261
Dipesh1995 wrote:
14 May 2019, 13:34
Link?
Xero
32
flexcon wrote:
14 May 2019, 13:21
They have gone more towards the same direction as Ferrari, but it's going for more out-wash, not in-wash.
Will be interesting to see if McLaren do some more extensive back to back tests with the old front wing, which can have the outboard section adjusted relatively high to create more frontal downforce. Maybe they're at a point where need to start sacrificing tyre wake management in order to get the front downforce they clearly need?
I can't remember seeing any comments from the weekend suggesting a change in the car's balance with the upgrade? I think tyre temp issues may have masked any improvements.
Nivedanm
Nivedanm
Jolle wrote:
14 May 2019, 11:40
Nivedanm wrote:
14 May 2019, 10:51
Just a quick question to aero/mech engineers out there. What gives a car the advantage in low speed corners? Mechanical grip enabled by suspension and chassis setup or aero configuration of the car? What does one have to do to improve low speed corners? Aero tweaks or suspension adjustments and chassis setup with a different ballast placement?
Mostly chassis and suspension. A ton of downforce helps as well, which doesn’t have to be efficient. Oh and good drivability, with the current PU’s, having lots of electric power from the apex.
Thanks for the info!
It's not quite that simple, it generates more in-wash under the wing and more outwash over the top of it.
M840TR
M840TR
315
