Before mgu-k they couldn't use full engine power with nas engines until 140 km/h. Now there is more power at lower rpm with higher torq. According to what I read about Honda Engine they are using mgu-k to generation at least until that speed. It is some kind of TC contrl Engine power and store some of unneeded engine power to use later.saviour stivala wrote: ↑17 May 2019, 20:25“The torque at start is that of PU (ICE+MGU-K)”. At start the torque is that of ICE alone, when the MGU-K is allowed to kick-in they would most probably already have up-shifted into second gear.
How do you think that affects the arguments I made in the rest of my post?saviour stivala wrote: ↑17 May 2019, 20:25“The torque at start is that of PU (ICE+MGU-K)”. At start the torque is that of ICE alone, when the MGU-K is allowed to kick-in they would most probably already have up-shifted into second gear.
**moved from another thread... don't know how it got misplaced**etusch wrote: ↑17 May 2019, 22:25Before mgu-k they couldn't use full engine power with nas engines until 140 km/h. Now there is more power at lower rpm with higher torq. According to what I read about Honda Engine they are using mgu-k to generation at least until that speed. It is some kind of TC contrl Engine power and store some of unneeded engine power to use later.
https://youtu.be/VxwyM_fo8Ss
For the gearchanges that happen when consistent traction is useful to the driver, in and around corners, I think it would be useful to maintain constant power. Assuming in qualification the power from the PU prior to the shift is 660kW then the PU could be switched off for 27msec, during which the 18kJ of inertial energy could provide the 660kW, and then the PU could pick up where it left off.gruntguru wrote: ↑16 May 2019, 07:14The numbers are different to your gut feel unfortunately. Using a low rotational inertia for the engine plus MGUK of 0.05 kg.m^2 and a rpm change on upshift from 12,000 to 10,500 we get a change in kinetic energy of 18 kJ. (To achieve this in 1 second would require a braking power of 18 kW). The MGUK has a power limit of 120 kW so it will slow the engine from 12,000 to 10,500 in 0.15 sec (150 ms). That is way too slow for a gearshift. If the shift was say 15 ms, the braking power required to slow the engine would be 1200 kW.
@SS.
18 kJ (actually something less) per gearshift would not destroy the clutch over the course of a race.
Definitely useful:
These ICE should have a fairly flat power band in the upper rev range when accelerating. The MGUK could be used to make things equal.
You mean to use MGU-K in generation mode during accelartion in order to simulate something like pasive traction control?etusch wrote: ↑17 May 2019, 22:25
action of ICE and MGU-K combined should be mapped to comply with the accelerator pedal-to-PU torque map rules
I think with the PU control maps, and "Diff magic" that the 2019 cars are probably light years ahead in "driver assistance" than the 2007 cars...Tommy Cookers wrote: ↑21 May 2019, 16:38the action of the ICE and the MGU-K combined should always comply with the accelerator pedal-to-PU torque map rules
ie the PU torque for a given accelerator position can't fall quicker than rpm rises - a constant power map as allowed in NA F1
(presumably constant though no-one here seems to have checked this exactly from the slope limit given in the rules)
the K's dynamic behaviour might collapse (and recover) its torque (driving or generating) if triggering factors were encountered
eg if there was a sudden change in eg wheel grip (driving or braking)
these dynamic response effects (somewhat like TC and even ABS) might not be seen as breaking the rules on mapping
and anyway they would be limited due to the limited size of the K
Never argue with an idiot, they will drag you to their level and beat you due to their experience...
