Can the MGU-K harvest or deploy under its own control? And related questions.
henry
324
Re: Can the MGU-K harvest or deploy under its own control? And related questions.
saviour stivala wrote:
22 May 2019, 18:01
Incredible and a pity that nobody from the lot of the three power unit manufacturers including the research work Profs Limebeer did for FERRARI back than could hit-on or consider these here presented mathematical equations and their resultant gains by having the MGU-K harvesting when off throttle but still not when braking. If any of the above lot did, the old days difficulties of keeping a topped-up ES for lap after lap by capturing kinetic/heat that would otherwise goes to waste only. Would have been solved.
You’re a keen F1 historian. Remind me how well Ferrari did against Mercedes in 2014.
Prof Limebeer’s published work, to which you refer, was both an exposition of how to do optimisation for the modes he and Ferrari chose to model and a marketing tool to extol how much more efficient the current PUs are in comparison to the previous V8s.
The more recent optimisation work in conjunction with Ferrari written about in the paper I referenced earlier and linked to by @subcritical71 explicitly describes the issues were talking about.
subcritical71
90
henry wrote:
22 May 2019, 18:25
22 May 2019, 18:01
If everything was thought of the first month after a major rules change there would be no in season, or season to season development necessary. I think we see at every race the teams are iterating, building on their knowledge and expanding the possibilities of what can work and what will not work. This becomes their toolbox to get the most out of their respective platforms. To say that every team has only the knowledge today as they had in 2013/14 is a bit incredible. Maybe at the time they had thought about it but were not able to develop it enough to put on the car, yet. As well, the teams would be able to make reasonable guesses at what others had thought about and been able to see if those solutions also would work for them.
saviour stivala
saviour stivala
51
From what has been consistently pushed-out on here it seems that the hybrid power unit designers and their financed highly rated researchers, the now claimed fact advantage of making the MGU-K to harvest when not braking totally escaped them for at least the duration of the first three years of the hybrid formula.
642
well didn't Honda in telemetry appearing on this site show it right from the start of their programme ?
