Hasn't this already been talked over a thousand times since the season began? Do we really need the same deduction yet every weekend?
No need to verify what I already saw, and commented on, right (we? eh, right)?siskue2005 wrote: ↑09 Jun 2019, 11:18From the graphics, he loses as soon as we brake for the corner and also continues to lose time (until the corner exit when the traction out of the corner is no longer dependent on mechanical suspension/downforce and pure engine power kicks in.)
You can verify that in the video below (btw great comparison)
[CUT out the very video I was talking about]
Firstly, if you look at my initial comment I only said that the discussion can not be put to bed. I am recognising there are clear advantages in Ferrari's engine, but you are neglecting the advantages that Mercedes may have over the Ferrari. So I don't think the advantages that Ferrari have atm can absolutely outweigh the disadvantages it may have.siskue2005 wrote: ↑09 Jun 2019, 12:26So based on just the fuel efficiency which was reported in 2018 you are saying Mercedes still the best engine?TheFluffy wrote: ↑09 Jun 2019, 12:15
Admittedly, the source of Mercedes having a more fuel efficient engine is from last year (I think it was amus) but it did say (at least for last year) they had a more efficient ICE. Of course, lots can change but extrapolating from last year's knowledge maybe it remains status quo.
Also, this is a very superficial observation, but the crazy packaging that Mercedes are able to achieve with their car may be down to having an efficient engine. Of course, it is probably predominantly because of their better cooling system. But efficiency MAY play a part.
1. even when ferrari can run higher engine modes through out the weekend,
2. even when ferrari can go faster in mid straights
https://serving.photos.photobox.com/549 ... 35c588.jpg
3. even when ferrari can have letter boxes as their sidepod entry for last 2 years
4. even when ferrari can pull out 0.3 sec just in one straight
https://serving.photos.photobox.com/653 ... dd718c.jpg
5. even when other ferrari powered teams are also power full
Still Mercedes engine is better than ferrari's!?
Right!!
Yes it's quite a common practice. Sometimes just for comparisons or for heating the tyres differently depending on the circuit.SmallSoldier wrote: ↑09 Jun 2019, 15:42Found the following picture, which I think it’s from one of the FP sessions (FP3)... Is Ferrari running different brake drums left/right?...
https://uploads.tapatalk-cdn.com/201906 ... 5fbb06.jpg
Thanks... First time I noticedMtthsMlw wrote:Yes it's quite a common practice. Sometimes just for comparisons or for heating the tyres differently depending on the circuit.SmallSoldier wrote: ↑09 Jun 2019, 15:42Found the following picture, which I think it’s from one of the FP sessions (FP3)... Is Ferrari running different brake drums left/right?...
I'm not sure that's the reason. Unless you're locking up a wheel, the load on both brakes should be the same.
if the heat dies down it'll be the opposite, Ferrari has a problem keeping heat in the tires not overheating them.vogonvader wrote: ↑10 Jun 2019, 18:00Now that the heat dies down a little, I wonder if Austria and France can turn out 2 other tracks where Ferrari might pull off another Canada? They both have long straights for Ferrari to take advantage of.
I think they have a good chance in Austria, especially with the right weather. Not sure about France, they were not on the pace there last year.vogonvader wrote: ↑10 Jun 2019, 18:00Now that the heat dies down a little, I wonder if Austria and France can turn out 2 other tracks where Ferrari might pull off another Canada? They both have long straights for Ferrari to take advantage of.
