No, because STR didn't want both drivers starting from the end of the grid with 10 places gridpenalty.
It is strange that this time there isn't numbers turning aroundIvailoStefanovBG wrote: ↑19 Jun 2019, 11:23Comparing the style of Tanabe`s words with previous statements my opinion is that power gain is significant.![]()
If the gap is estimated to be ~40hp then another 15 would leave a 25hp deficit, and a small improvement in the chassis would put Max close enough to challenge at all tracks. I honestly don't think they made that much inroads, 10hp and better MGU-H and turbo efficiency. Maybe they can generate a little more electrical energy per lap, so while it may not increase peak power it may improve the power band and fuel economy. Every little bit helps, a small improvement in drivability, needing to carry less fuel, all these things start adding up.
I think that Honda already have some secrets that others should not know. From this time on we will hear less and less numbers from them. If Redbull and Honda updates work fine they will challenge Mercs.etusch wrote: ↑19 Jun 2019, 15:55It is strange that this time there isn't numbers turning aroundIvailoStefanovBG wrote: ↑19 Jun 2019, 11:23Comparing the style of Tanabe`s words with previous statements my opinion is that power gain is significant.![]()
I've read on the verstappen forum the update is worth 30 kW - though not all of the power will available to use straight away.etusch wrote: ↑19 Jun 2019, 15:55It is strange that this time there isn't numbers turning aroundIvailoStefanovBG wrote: ↑19 Jun 2019, 11:23Comparing the style of Tanabe`s words with previous statements my opinion is that power gain is significant.![]()
I heard its 50.Snorked wrote: ↑19 Jun 2019, 16:52I've read on the verstappen forum the update is worth 30 kW - though not all of the power will available to use straight away.etusch wrote: ↑19 Jun 2019, 15:55It is strange that this time there isn't numbers turning aroundIvailoStefanovBG wrote: ↑19 Jun 2019, 11:23Comparing the style of Tanabe`s words with previous statements my opinion is that power gain is significant.![]()
Yes now there are numbers
