JordanMugen wrote:FrukostScones wrote: ↑18 Jul 2019, 19:57
first one got me confused, but as I expect from all of you the same result of 100%.
I'm not so confident as you, lol.
Mercedes, McLaren and Force India have distinctive noses. Apart from that, I would struggle to tell the difference.
IMO, it would be very difficult to pick the difference between Toro Rosso, Renault, Alfa Romeo, Ferrari, Williams and HAAS without livery.
Alfa Romeo should be pretty easy to identify, similar to Mclaren with the 3 openings in the nose, but the side ones are oversized compared to the center one... Their unique front wing also makes it relatively easy to identify.
Ferrari has an stub nose that is “square” and the outwash wing, which should be easy tell apart from the Haas, Renault and Williams... You could confuse it with STR, but their stub nose is wider at the back... If that’s not enough the air inlet is completely different and the Ferrari one stands out... Red Bull is also easy to identify since their nose has an opening and the tip doesn’t follow the slope of the nose, going “upwards”... And they have the only stub nose with a similar wing to Mercedes, so relatively easy to identify too.
The only ones that I could see some difficulties with is between Haas and Renault, but Renault has the widest stub nose of them all.
I took the poll and only had to really look for the difference between Renault and Haas, the rest seemed pretty straight forward.
