Holm86
247
Re: 2021 Aero Thread
If the wheel covers are so good at cleaning up air-flow, why were they banned in the first place when most teams ran them on the front wheels a few years ago?? Was it because of pitstop issues???
Holm86 wrote:
01 Aug 2019, 14:16
Well...
https://www.motorsport.com/f1/news/f1-l ... 10/336059/
Holm86
247
turbof1 wrote:
01 Aug 2019, 14:24
Holm86 wrote:
01 Aug 2019, 14:16
Well...
Thats exactly how I remembered it, but now all of the sudden it's supposed to help???
Singabule
Singabule
Holm86 wrote:
01 Aug 2019, 14:27
turbof1 wrote:
01 Aug 2019, 14:24
Holm86 wrote:
01 Aug 2019, 14:16
Well...
If F1 can govern it nicely, it may reduce overall tyre wake and improve efficiency then improving speed at the same time. For example half closed rims for indy and LMP car. This May also reduce aero work on brakeduct cover.
jjn9128
778
Holm86 wrote:
01 Aug 2019, 14:27
They serve a different purpose. The 2009 covers were an aid to brake cooling, punching the hot air from the wheel hubs outboard - like the blown axle. The 2021 covers are more a means of cleaning up the turbulence from the bigger wheel rims. There will have to be some exit hole so it will interesting to see how the FIA word the rules...
#aerogandalf
All this talk about aero, but why does no one talk about cars that can survive some wheel banging when drivers go toe to toe. The cars themselves are sturdy, but the wings are not, and they have a propensity for puncturing tires.
FPV GTHO
FPV GTHO
Holm86 wrote:
01 Aug 2019, 14:27
turbof1 wrote:
01 Aug 2019, 14:24
Holm86 wrote:
01 Aug 2019, 14:16
Well...
I think it could be down to more understanding of the issue. The OWG also claimed for the 2009 rules that they found venturi tunnels to be more sensitive to turbulence. They've done a 180 flip there too.
djos
113
To be fair to the OWG, I don't think they ever had the kind of resources that Brawn now has to work with.
"In downforce we trust"
roon
roon
412
Let's bring back grooved tyres, keep the halo, add a windscreen to it, with safety lights, place the driver higher up for better visibility, increase the size of the rearview mirrors, eliminate aero devices, return to front engine for a vintage feel, keep the high compression engines, and point the exhaust FORWARD to eliminate any aero trickery. I did a quick rendering here in a Caterham livery:
Xwang
Xwang
29
roon wrote:
02 Aug 2019, 05:00
https://d3lp4xedbqa8a5.cloudfront.net/i ... -1-(1).png
For sure it will be funny! :-)
jjn9128
778
djos wrote:
02 Aug 2019, 03:59
They had $250k to do CFD and wind tunnel tests and less than a year to do the work. Plus they were all in full time employment within teams.
#aerogandalf
djos
113
jjn9128 wrote:
02 Aug 2019, 08:17
djos wrote:
02 Aug 2019, 03:59
Exactly, this is less than most teams spend annually on catering.
Holm86
247
jjn9128 wrote:
01 Aug 2019, 15:06
Holm86 wrote:
01 Aug 2019, 14:27
I do not agree, they were inventet on the reason of aerodynamics, not because they needed more brake cooling.
But i agree that the opening in the bottom was to push out hot air, aiding the outwash. But the new ones on the concept render for 2021 has the same cutouts ...
jjn9128
778
Holm86 wrote:
02 Aug 2019, 09:28
Brake cooling is an aerodynamic issue. I never said it was for more cooling but to aid the cooling flow while pushing air outwards. A significant part of a duct flow is the exit - the covers helped to increase through flow for the brakes which meant smaller inlets and admittedly also a small wheel/brake system drag saving. The effect was that the air was punched outwards more though which is detrimental to following (as the 2019 rule changes were intended to cut this effect). Why do you think this sort of wheel rim became the design du jour in 2010 (until the FIA decided to limit the wheel design)? It's working like an A/C diffuser to expand the air exiting the wheel.
From Sprot, 2013
There was, for a short time, a popular design direction in F1 whereby outboard wheel fairings were used in order to improve the aerodynamic effect of the wheels on the overall flow-field. Typically these comprised complete discs with holes cut out, or a section removed... The presumption is that the control of the exit air flow allows the reintroduction of the cooling flow into a more favourable section of the wake. In addition to this, by restricting the size of the exit orifice, the velocity of the reintroduced air will be much higher resulting in a lower outboard pressure which helps to divert the wheel wake away from vital downstream components.
#aerogandalf
jjn9128 wrote:
02 Aug 2019, 10:06
Holm86 wrote:
02 Aug 2019, 09:28
http://www.formula1-dictionary.net/Imag ... l_2010.jpg
From Sprot, 2013
You just know F1 is extreme when they introduce diffusers for their wheel rims :lol:
(I actually want diffuser wheel rims now...)
