Lol [-XWhiteBlue wrote:no, I have no proof for this. I'm just deducting. Perhaps I should be a bit less positive about it when I talk about my own conclusions.Tomba wrote:Is that your own assumption or do you have proof of that. Personally I'm pretty sure that the rear tyres were not the problem, but rather the harder sidewall of the front tyres. Renault have required a year or so to fully understand the problems their car had with the Bridgestone tyres, and the result is paying off....WhiteBlue wrote:2. The cooling vent hitting the tyres were smoothing them up making for a simmilar behavious compared to the Michelins with the very dynamic side wall that they knew.
The long version is that the Michies had an extremely flexible side wall which was rumored to be achieved by incorporating a thin steel band. That transpired from the 2005 Indy desaster where they had a resonance problem that destroyed the side walls.
Renault were known to have raced mass dampers in front and rear to take advantage of the superior traction of the soft side walls without suffering too much penalty over bumps and curbs.
During this season Renault got back into the mass damper business with the J-Dampers and sure enough they look for compensation of the stiffer Bridgestone design. You reported the tyre heating aero trick. It seems to fit together.
Regarding the heating of the front tyres I guess that is less of a problem because they receive a ton of heat from the brakes. front brakes dissipate the lion share of the brake energy and they could have adjusted their ducting without someone knowing it when they kicked in with the J-damper. they may have left the rear to fiddle with for later because it did not have the immediate advantage they could initially achieve at the front.
thinking about this I can imagine that the wheel fairings play a big role in keeping the rims hot. they appeared around the time when J-dampers started to spread in the paddock and it was always denied that they have a primary aero function. what if they are mainly there to stop convection cool the wheels and thus the tyres?
Please, are you even an engineer.
If you are, you're pretty poor at proving a point and full of unsupported theory/assumption.
"It seems to fit together"
I will never forget that. =D>
Tomba, I really agree with Conceptualist's post. It sums up Whiteblue perfectly. It's evident in most of his posts [that I have read - since I don't frequent here as much]
