[MVRC] Mantium Virtual Racecar Challenge 2019 (Grand Prix Cars)
rjsa
rjsa
51
Re: [MVRC] Mantium Virtual Racecar Challenge 2019 (Grand Prix Cars)
I’ll figure that out. It’s jut too little time I have & I was counting on throwing it in and be ready. I’m not sure I’ll have a complete, legal car with at least one sim done - that wll have to do for the 2 first races.
Schedule was too tight.
LVDH
46
rjsa wrote:
08 Aug 2019, 18:01
Hi there, mflow is culling geomery:
"current file name: Z_Suspension_frt_V01.stl
current file name: Z_Suspension_rr_V01.stl
current file name: Z_Wheels_frt_V01.stl
current file name: Z_Wheels_rr_V01.stl
The demo version of MantiumFlow only accepts a maximum of 30 stl files!
Everything above that will not be used for this simulation."
I just checked the code. Are you sure you are not using one of the MVRC templates? If so, the limit should be disabled.
I am always working on the code and it seems like I implemented something for very challenging cfd simulations that also helps on the MVRC cars. I will test a bit more on the cars but I think I will release a new version this weekend so you guys can benefit from this improvement. Would just be good to confirm that the stl limit is deactivated when choosing an MVRC template.
rjsa
rjsa
51
I didn’t get to the template point, so yes, must be it. I’ll check.
rjsa
rjsa
51
MVRC_Long has the limit of 30 files.
rjsa
rjsa
51
Now it's complaining about rear wheel position, I guess those should not be merged to the rest.
And it won't build because I don't have blueCFD on the machine, how do I do it to skip this verification?
Warning: MantiumFlow could not find the configured blueCFD installation path.
 right now it is set to: C:\Program Files\blueCFD-Core-2017
Warning: Rear wheels seem to be positioned incorrectly. In MVRC they should be in global (3.4,0,0).
writing case: E:\CFD\2019f1_mk01_0001
rjsa
rjsa
51
The problem with the wheels wasn't merging with the other parts. I've got them separated now and sill get the error message.
rjsa
rjsa
51
It is running despite the wheels and bluecfd error messages.
BUT:
60803 wall                MVRC_bool_reduced_patch60794
60804 wall                MVRC_bool_reduced_patch60795
60805 wall                MVRC_bool_reduced_patch60796
60806 wall                MVRC_bool_reduced_patch60797
Seems to be on and endless loop.
No it's not caught on a loop, moved on to another part.
Ft5fTL
26
I finished my first couple of cfd's with the new software and my new cpu. There is some significant difference on the results that i got from different cfd options.
Time = 1200
forceCoeffs forceCoeffs write:
    Cm    = 0.27190957
    Cd    = 1.1457955
    Cl    = -1.63347
    Cl(f) = -0.5448254
    Cl(r) = -1.0886445
Time = 1200
    Cm    = 1.366718
    Cd    = 1.1547571
    Cl    = -1.4156811
    Cl(f) = 0.65887749
    Cl(r) = -2.0745586
The first one is the standart MVRC option. Second one is the MVRC_Fast option with same car. I think this is a serious thing since i often use the fast option for quick results.
Mantium Challenge - Pure Power Racing
CAEdevice
50
I have about the same differences, I think it is normal considering the mesh settings.
Team_Bart
Hi Guys, I jus read the email about the new season. Nice to see you managed to design a complete set of rules! I hope it will attract a lot of new competitors because I think this is one of the best engineering competitions which is accessibele for anyone. You can really learn a lot skills in engineering and aerodynamics in specific.
Unfortunately I decided to not join (the beginning of) this season. Last season I was really enjoying the competition and I learned a lot. The main reason is that I have too little time to run the simulations on my laptop. I hoped to find a solution for this but I still have none :(
Good luck all with the development of your cars, I will keep follow the competition and probably I can join later.
Ft5fTL
26
CAEdevice wrote:
09 Aug 2019, 20:35
What is the point having a fast option if it gives complete different results than the full one? I don't think that's normal. I dont know what changed as settings but i always used the fast option on the previous years software (even on my F1 car) and i never got a positive lift value.
CAEdevice
50
Ft5fTL wrote:
09 Aug 2019, 20:56
CAEdevice wrote:
09 Aug 2019, 20:35
I agree, it is not useful. I edited the mesh setting manually in order to obtain a compromise.
Btw, good numbers compared to mine. If you are ok with cooling, Variante will have another competitor.
variante
138
Ft5fTL wrote:
09 Aug 2019, 20:27
Time = 1200
    Cm    = 0.27190957
    Cd    = 1.1457955
    Cl    = -1.63347
    Cl(f) = -0.5448254
    Cl(r) = -1.0886445
Time = 1200
    Cm    = 1.366718
    Cd    = 1.1547571
    Cl    = -1.4156811
    Cl(f) = 0.65887749
    Cl(r) = -2.0745586
Why "Time = 1200"? Iterations in "fast" go up to 2000; in "normal" even more, probably. Given the different settings between "normal" and "fast", i don't think that residuals compare. Let them converge and then lets see what happens.
I've just completed my first simulation in "fast" and everything seems right.
BTW if anyone has similar info about fast and normal, please share because i probably won't have the time to do any comparison.
Team_Bart wrote:
09 Aug 2019, 20:41
Come on! We're all late...I've made my first simulation today after putting together a car in 3 days!
Ft5fTL
26
variante wrote:
09 Aug 2019, 23:21
Ft5fTL wrote:
09 Aug 2019, 20:27
Time = 1200
    Cm    = 0.27190957
    Cd    = 1.1457955
    Cl    = -1.63347
    Cl(f) = -0.5448254
    Cl(r) = -1.0886445
Time = 1200
    Cm    = 1.366718
    Cd    = 1.1547571
    Cl    = -1.4156811
    Cl(f) = 0.65887749
    Cl(r) = -2.0745586
I quit that one around 1250. Thats why i posted the results at 1200. I completed 3 sims at fast settings, i ended up with these results:
Cd: 1.1227065555, Cl: -0.3831973513, Cl(f): 1.7312270195, Cl(r): -2.1144243705, CoP: 18.761
Cd: 1.1888227472, Cl: -1.7330100288, Cl/Cd: -1.4577530863, Cl(f): -1.7699407171, Cl(r): 0.0369306882, CoP: -0.072
Cd: 1.2144504931, Cl: -1.8959802335, Cl/Cd: -1.5611836335, Cl(f): -1.7225041266, Cl(r): -0.1734761067, CoP: 0.311
rjsa
rjsa
51
@Andre, what causes this?
It happens with the provided parts I decimated using magics to reduce size.
