I guess before stablishing the rules they first need to understand the concept they´re introducing. Then they can say what´s allowed and what´s banned, but for that they need to develop a real car to see how it´s working in the real worldizzy wrote: ↑22 Aug 2019, 20:48it is awesome isn't it. I can't help thinking the FIA are designing the car tho, an awful lot, instead of setting limits and letting the teams design them. I mean it's great they're trying so hard to get good racing with following and passing, but they do seem to be producing 'the car'.
Yes thinking about it and reading the racefans article, they can do A car as you say, to prove the concept, and then do the regs with scope, with boxes and hopefully not a million sub-clauses.Andres125sx wrote: ↑26 Aug 2019, 20:55
My thoughts as well. Some say the teams have a role in ratifying this FIA proposal. Perhaps it will pass, perhaps it will be voted down. Will there still be legality boxes? Where and what size?astracrazy wrote: ↑26 Aug 2019, 16:58I do wonder if this is the end of f1 as we know.it though. How much allowance in the rules is there going to be for innovation and out of the box ideas.
What is the issue the rear wing is causing?
Space. A wind tunnel working section is only so long, and the rolling road section is even shorter, if you want to put 2 models in the tunnel you have to reduce scale to get any sort of meaningful separation. When you reduce the scale you reduce the Reynolds number - in other words the effective speed of the car (in a wind tunnel the "real world" speed is directly proportional to the scale, i.e. a 50% scale model at 100mi/hr in the tunnel is only simulating 50mi/hr at the track), which makes the test less representative of conditions at the track. They can run 2 car simulations in CFD (albeit requiring more computing time and resource) so the wind tunnel becomes a validation tool to check against the computations.
Are there any tunnels out there actually long enough? I'd imagine all tunnels are only built with the 1 car in mind more complex stuff can be done in CFD.Smokes wrote: ↑27 Aug 2019, 13:26I guess they couldn't afford to run the model in a longer tunnel...
My only concerns we can validate the the wake of a single car CFD in this test but we cannot validate the computation of a single car following another using a wind tunnel.
As using a tunnel may throw some surprises that the CFD didn't account for. if the tunnel is calibrated correctly...
I don't believe there are any wind tunnels out there with a long enough working section and a rolling road to run 2 large-ish scale F1 models. None spring to mind anyway. Wind tunnels aren't perfect anyway so the combination of tunnel and CFD is always going to be the best approach. They're running much bigger CFD meshes than the teams (no limit on flops and cores) they'll also be running this test at a higher Reynolds number than teams (they can only do 60m/s at 60% scale whereas the Sauber tunnel can run up to 300km/hr or 83m/s)Smokes wrote: ↑27 Aug 2019, 13:26I guess they couldn't afford to run the model in a longer tunnel...
