McLaren MCL34
f1rules
f1rules
589
Re: McLaren MCL34
i think it has aero purpose also, this picture is from when it was painted in flowvis, easy to see it interacts with pod deflectors, further the shape is basicly a symetric airfoil, will that not increase the velocity of the flow there if they can keep it attached
https://media-cdn.mclaren.com/media/ima ... 4I8386.jpg
f1rules
f1rules
589
Re: McLaren MCL34
bosyber
bosyber
45
Re: McLaren MCL34
From the article:
McLaren's new suspension set-up features a reworked upright mounting, featuring a larger extension for the top wishbone to connect to.
Previously, the horn-shaped extension had the wishbone sit on top of it, but this has now been made larger and allows the wishbone to connect to the side.
In doing so, this shortens the overall wishbone length and redefines the manner in which the suspension travels on turn-in.
It appears that McLaren wishes to further reduce the amount of roll in the corners, providing the car with a more stable aerodynamic platform along with a more consistent level of tyre contact.
Re: McLaren MCL34
That's a bit of a weird article, raising the outer pickup points would generally increase roll slightly, not decrease it. And the pivot is still internal to the bracket, not on the side.
Anyway the height change is so small that the amount of roll difference would be negligable - it's camber gain/KPI and/or aero related, not roll resistance.
M840TR
M840TR
314
Re: McLaren MCL34
Also interesting to note is the fact that this was the second front-end solution the team tried this season with no success.
trinidefender
trinidefender
317
Re: McLaren MCL34
M840TR wrote:
02 Sep 2019, 00:37
How do you know there was no success? Both ideas could have simply been for data collection so the team know where to move forward with future development. These revised uprights are clearly test items and not meant to be raced.
Re: McLaren MCL34
What was the first they tested without later fitting?
f1rules
f1rules
589
Re: McLaren MCL34
interesting info, not related to mclaren but about tech. Danish journalist peter nygard, +20 years in the paddock as fotographer, and close to kevin and haas, in an article yesterday mentioned that haas has one rear hydraulic suspension available from ferrari and this weekend it was grosjean, the interesting part, the advantage, it will lower the rear on the straights which yesterday gave grosjean 6-7kmh on magnussen in qual
M840TR
M840TR
314
Re: McLaren MCL34
PhillipM wrote:
02 Sep 2019, 04:11
PoU.
martinbeiker
martinbeiker
Re: McLaren MCL34
M840TR wrote:
02 Sep 2019, 11:04
PhillipM wrote:
02 Sep 2019, 04:11
PoU.
Didn't we race that in Hungary?
FittingMechanics
FittingMechanics
16
Re: McLaren MCL34
martinbeiker wrote:
02 Sep 2019, 12:17
No, it was just tested.
Re: McLaren MCL34
It was on the cars during the race in Hungary.
FittingMechanics
FittingMechanics
16
Re: McLaren MCL34
PhillipM wrote:
02 Sep 2019, 14:37
My apologies in that case. I was under impression that it's still in testing.
_cerber1
239
Re: McLaren MCL34
PhillipM wrote:
02 Sep 2019, 14:37
In Hungary, Seidl said that of the updates they only had a rear wing and diffuser elements. He did not say anything about the suspension.
Re: McLaren MCL34
If you go to where that image is originally from, you can see it on the pushrod clearly.
