Scuderia Ferrari SF90
Re: Scuderia Ferrari SF90
https://twitter.com/AlbertFabrega/statu ... 01539?s=20
Presumably an attempt to add front end downforce. Looks like a mini car underfloor below the nose.
Via @andihaupt1
Vertical fins on the floor too
Along with revised ones in front of the rear wheels
Ashwinv16
60
2008 said hello, hope it doesn't disrupt flow into the floor
Halo not as bad as we thought
timbo
timbo
111
I thought you have to create a twist in the channel so the you cannot see through, am I wrong?
f1316
f1316
82
It’s basically a mini cape behind the new nose - interesting that they still chose not to extend the cape further ala Mercedes et al; you’d think there’d be some dirty downforce available in doing that.
Mamba
Mamba
timbo wrote:
19 Sep 2019, 14:06
I think the Ferrari nose already meets the two cross section regulation thus this is only an add-on below the nose structure. The RP & Alfa noses employ a trick in the regulations to include those slots in the structure but they still have to comply with the cross-section rules & enclosed surface rule (?), thus they cannot be "see through" like here.
My reasoning at least...
lio007
316
Some nice shots:
AMuS
Ashwinv16
60
f1316 wrote:
19 Sep 2019, 14:45
But drag too, a lot of it.
Singapore rear wing
Via AMuS
A nice close-up of the steering wheel
zibby43
zibby43
613
It's not exactly new, now i believe it's been introduced in Hungary together with the new barge boards, but definitely flown under the radar in this topic is the new(ish) support for the X-vane (black element connecting the X-vane to the crash structure).
f1316
f1316
82
Ashwinv16 wrote:
19 Sep 2019, 16:32
f1316 wrote:
19 Sep 2019, 14:45
Which I wouldn’t expect them to be concerned about in somewhere like Singapore.
f1316 wrote:
19 Sep 2019, 14:45
It's point isn't to create downforce per se, but rather create a vortex. For example Mercedes has the cape much longer than everyone else, but they also don't run the vertical elements under the nose.
