Hope you are spot on again chap.
I'd expect Bottas right behind the Ferrari's. This may be the one track that he has on Hamilton...Just_a_fan wrote: ↑23 Sep 2019, 18:52Isn't this just another Singapore but with a big curved corner in place of one of the left-right-left things. It's two almost straights with lots of 90-ish degree bends. Ferrari will be mighty on the main "straight".
I don't see why Ferrari won't be at the top again.
Lec, Vet, Ham, Ver, Bot - quali and race.
Don't forget this track is smooth, so it's even harder to get heat into the tires and keep them at temp. Ferrari might have to add more DF than they would like to maintain tire life.
No, because you don't need nearly the delta to pass someone.Just_a_fan wrote: ↑23 Sep 2019, 18:52Isn't this just another Singapore but with a big curved corner in place of one of the left-right-left things. It's two almost straights with lots of 90-ish degree bends. Ferrari will be mighty on the main "straight".
But it is run in daylight (sunshine) and the corners are slightly longer, so track heat and more lean should get heat in and harder tyres.
You might be right about Bottas giving Hamilton a hard time. If there are tracks Hamilton is weak on, Russia is one of them. Beat his teammate in qualifying just once (2014) there.Zynerji wrote: ↑23 Sep 2019, 19:01I'd expect Bottas right behind the Ferrari's. This may be the one track that he has on Hamilton...Just_a_fan wrote: ↑23 Sep 2019, 18:52Isn't this just another Singapore but with a big curved corner in place of one of the left-right-left things. It's two almost straights with lots of 90-ish degree bends. Ferrari will be mighty on the main "straight".
The entire weekend is supposed to be overcast with a good chance of rain all 3 days, and a high of only 23°C.Big Tea wrote: ↑23 Sep 2019, 19:17But it is run in daylight (sunshine) and the corners are slightly longer, so track heat and more lean should get heat in
Right, back to the drawing board then
