Due to the lighting in Singapore it is quite easy to see the dash of the steering wheel.
What I found interesting is that Vettel's battery was nearly empty going in to turn 7 on the first lap. He hadn't used that much energy at the same point in Q3. He got to the straight (on first lap) with the same SOC but used quite a bit more energy on it than in Q3.
For sure in Quali you're chaising the best laptime and on the first lap you want to maximise your chances to overtake on the straight.
But wouldn't that mean that Ferrari isn't using max. deployment in kW there in Q3 though?
I guess in both cases the PU is in e-boost mode but one uses more energy than the other? Could that be explained by fuel load? Or is there a different reasoning behind it?
