You can’t. The batteries, if there are more than one, are joined together in the Energy Store and there is only ONE connection for both the K and H to the ES.
One thing is sure, it doesn't blink when it's important so when he needs full power.LM10 wrote: ↑14 Oct 2019, 22:05https://streamable.com/0j6t6
Credits to Juzh. That's the video of Hamilton chasing down Vettel in the last laps of Suzuka. The red lights on the Ferrari blink quite often during a lap. Between turns 3 and 4, at turn 6, approaching turn 8 and turn 9, at turn 10 and eventually approaching turn 14. Is there anything we can conclude from that? Is it normal behaviour which happens on other cars as well?
Thank you for your explanation.MtthsMlw wrote: ↑14 Oct 2019, 22:28One thing is sure, it doesn't blink when it's important so when he needs full power.LM10 wrote: ↑14 Oct 2019, 22:05https://streamable.com/0j6t6
Not on the straight (only while lifting/braking for turn 1 but not everytime) and on the run to 130R.
Depends on pre programmed ERS settings and/or use of manual ERS overwrite buttons, in Ferraris case that would be K1 or K1+ for example.
I would be surprised if only Ferrari could do that.
That's not really his decision, he can only demand full power when he needs it by pressing a button. He doesn't need to manually conserve power or harvest.LM10 wrote: ↑15 Oct 2019, 00:26Thank you for your explanation.MtthsMlw wrote: ↑14 Oct 2019, 22:28One thing is sure, it doesn't blink when it's important so when he needs full power.LM10 wrote: ↑14 Oct 2019, 22:05https://streamable.com/0j6t6
So does that mean that in sections when he needed full power he didn't use it, but decided to use it elsewhere?
Alright, makes sense, thank you.MtthsMlw wrote: ↑15 Oct 2019, 08:25That's not really his decision, he can only demand full power when he needs it by pressing a button. He doesn't need to manually conserve power or harvest.LM10 wrote: ↑15 Oct 2019, 00:26Thank you for your explanation.MtthsMlw wrote: ↑14 Oct 2019, 22:28
Obviously the more you can harvest where it's not hindering you in a battle the more margin you have to use it manually.
the turbo correspondingly boosts the amount of nitrogen etc - so combustion isn't improved (for a given temperature)atanatizante wrote: ↑16 Oct 2019, 16:32... turbo’s basic requirement is to make the engine’s combustion process more efficient by compressing the air before it enters the combustion chamber, which boosts the amount of oxygen being pushed through and means more of the fuel experiences complete combustion. ..
,,, how about a liquid oxygen small container which sprays certain amounts into the ICE air intake when you need the most?
It is not permitted, see belowatanatizante wrote: ↑16 Oct 2019, 16:32Regarding the air necessary for combustion, it`s a known fact that a turbo’s basic requirement is to make the engine’s combustion process more efficient by compressing the air before it enters the combustion chamber, which boosts the amount of oxygen being pushed through and means more of the fuel experiences complete combustion.
In other words, the more oxygen you got the better combustion is, isn`t it?
So, I have a little theory about Ferrari`s trick: how about a liquid oxygen small container which sprays certain amounts into the ICE air intake when you need the most? They could say it`s for reliability reasons like Renault did back in 2011 with that cold blowing … or maybe they have the best compressor on the grid which is running at the max. only on those particular moments …
My two cents
Ok, thanx for clarifications. So maybe a liquid nitrogen container? ...Tommy Cookers wrote: ↑16 Oct 2019, 17:48the turbo correspondingly boosts the amount of nitrogen etc - so combustion isn't improved (for a given temperature)atanatizante wrote: ↑16 Oct 2019, 16:32... turbo’s basic requirement is to make the engine’s combustion process more efficient by compressing the air before it enters the combustion chamber, which boosts the amount of oxygen being pushed through and means more of the fuel experiences complete combustion. ..
LOx was used in record breaking eg by Eldridge c.1925 - but it handles better as gas or in the fuel eg as nitromethane
As Xwang already wrote, the rules don't allow anything to be added to the intake air except for fuel.atanatizante wrote: ↑16 Oct 2019, 21:17Ok, thanx for clarifications. So maybe a liquid nitrogen container? ...
In addition, I`m sorry for not being up to date but what're the latest rumours/theories regarding why Ferraris PU has such an advance to the Merc one? I mean, somebody had figured out why they accelerate faster than Merc when the car reaches ~ 230km/h?
It's interesting to then degree that It shows rival teams do not exclusively believe the energy store / current / battery management to be the advantage.
