He said it in the presser ... it's just before the bit dans quoted
LH: And then I obviously got torpedoed. I thought at some stage I’d get torpedoed by Max. And then after that trying to keep up with Seb was a real challenge. A first and third is a true showing of real strength and depth with our team and it’s a real pleasant surprise really, because we didn’t expect our tyres to go as far as they did. We didn’t think we could manage a one-stop and we made it work.
Q: You said you were expecting a bit of action from Max early on in the race. Talk us through those opening corners?
LH: I actually got a really good start, so I was pulling up to Charles and Seb is coming across, coming across, coming across and I’m thinking ‘I’m on the white line, I don’t have anywhere further to go’. And he just keeps coming. So I had to avoid crashing with him, going on the grass. Avoid his wheels as well, otherwise I could have caused a big collision for him. Then I was surrounded by a bunch of cars, I braked into Turn 1, and all of a sudden Max is alongside me. If you’ve seen races before, I always leave Max a lot of space – it’s the smartest thing you can do. But there wasn’t a lot of space to give him space. I think he had an oversteer moment or something and then I got a massive hit from behind. Then I nearly took him out…
SV: He hit you?
LH: Yeah.
It wasn't quite a Kvyat like torpedo but two unnecessary contacts when they were side by side ... so blunt language but still true
It wasn't that obvious from other camera perspectives but the bold part straight up isn't true:
At the start we saw you flexing your muscles on the run down to Turn 1 to Lewis?
SV: Not really. I didn’t see him. He came after the race as well and asked, but no intention to push him or anything. Obviously, as soon as I saw, I obviously got off and I tried to get in Charles’ tow and I checked the mirrors on the right and the mirrors on the left and that’s when I saw Lewis and then, you know, I tried to go right but before that point I didn’t see him. We see quite well in the mirrors but there is still obviously an angle that you can’t see.
He actually moves over twice and never properly moves away from Lewis, does he?
https://youtu.be/QGA-SsBz_1I?t=584
