turbof1 wrote: ↑05 Nov 2019, 13:57
I gave it some more thought in light of an upcoming article.
The whole impression made by the community now, the one where it is claimed that Ferrari sends electronic interference into the fuel flow sensor, is frankly bollocks. I am sure this has been hit already, but can you imagine what that requires?
-You'd need some sort of device that is capable of precise interference inbetween the 2000Hertz measure points. Timing has to be impecable, the interference has to be impecable.
-This has to be done under racing circumstances. When the car hobling, vibrating and cornering around.
-And it has to be done in a fashion where at the very least its main purpose is not to interfere with the fuel flow sensor. It has to be "accidental". Can you sell such a precise controlled signal and frankly impressive technology behind it as accidental?
If that was the case, we would not be talking about Ferrari potentially cheating. We'd be talking about Ferrari signing their multi billion contract with the military for their new EMP stealth device that can be confused for accidental interference.
If something out of the Technical Directive did put a curve on Ferrari's performance, big if, it has to be in the other 2 questions RBR asked.
When the car is hobling, vibrating and cornering...? You mean under which the entire car and all its electronics already operate and have been since the last decade?
No disrespect Turbo, but what is your technical knowledge on what you call “bollocks”? Do you have any technical background on the sensors the FIA uses, how they are supposedly protected, in what kind of margins and tolerances they operate to know how such a device could be fooled and how difficult it would be within the context of F1 being a multi billion venture for most?
IMO, those details of the workings of the sensor would NOT be public knowledge - it would be daft to share it, as it would give a team basically a free invitation to try to cheat/manipulate the system.
Also, interference doesnt necessarily imply manipulation. Would a team be disqualified if the FIAs own supplied sensor failed throughout the race and they had no means to know if a car would be then exploiting that? No, because the team wouldnt know the sensor failed and would have to assume at all times that its working and to not risk disqualification. However, if someone were to be purposely interfere and causing more failed readings, but within margin, perhaps the FIA would assume all is correct and concentrate on the readings they have to draw conclusions from. Either way, we couldnt know, because i dont expect the FIA to come out and say “oh we have many failed readings”, let us take a look. They’ll just come and look...
