I think this should make clear Ferrari were testing high downforce package in Austin.
https://twitter.com/Vetteleclerc/status ... 68256?s=19
Thank you for cleaning up, including my post which was a reaction to a kind of provocative post. Quite annoying to hear and read the accusations even though nothing is clear.turbof1 wrote: ↑07 Nov 2019, 14:21I am locking down the topic for a moment to get some cleaning going on. I stated multiple times this is not moral thread. We had a very great, technical discussion going without any assumption, accusations, bias or emotional riffraff going towards Ferrari. I am seeing that now some people like to pull that focus away and towards a mud throwing contest.
Anything coming from the media going into this topic has to be TECHNICAL. It has to contain details about software, hardware, procedures, whatever. It cannot be baseless accusations quoted from F1 people.
EDIT: reopened. Please keep discussion down to hypotheses and conjecture based on the hardware and regulations (and how to possibly break and/or circumventthe regulations). Media spatouts from team personel are controversal juicy bits, but for any tech savvy out here, the juicy bits are the technical debates!
Photos like that can't be used as proof. First, they are all not of the same perspective Japan being different. Secondly we have no idea what the speeds are. Japan looks like part way through 130r, I'm not sure what Mexico is, and cota looks like a turn in the s's.CriXus wrote: ↑07 Nov 2019, 15:56I think this should make clear Ferrari were testing high downforce package in Austin.
I suppose it can be done by having a device akin to a hydraulic cam phaser on the pump.ncx wrote: ↑06 Nov 2019, 17:30Yes, stabilizing the frequency and phase of the peaks per se is fairly unproblematic, at least in principle, but how would you propose (hypothetically, of course) to control the _relative_ phase of flow peaks vs FFM measurements? If your proposal involved a U/S detector, we would be back into the first reply of mine.
Pulsating flow is a pretty standard problem for fuel flow meters. There are different ways of handling it. Just increase the sampling rate. And yes as you rightly said, there will be some time base that the system is damped to. Teams still wouldn't get much time to use their new found power boost, Because Ferrari want this boost for a few seconds, not milliseconds.Tommy Cookers wrote: ↑07 Nov 2019, 13:08this is not truesaviour stivala wrote: ↑07 Nov 2019, 09:56.... all fuel flow through the injectors the final point of the flow system including the fuel pressure and temperature goes through the FIA data logger.
.... final fuel flow through the injectors can finally be logged and verified....
the final fuel flow can be estimated this way
this isn't fuel flow unless the actual injectors actual flow in response to the actual signals is actually measured
measured with what ? ...
an FIA-calibrated ultrasonic fuel flow meter - every car should have one !!
or should the FIA own a stock of injectors and issue them to the teams for each event ?
and mandate the signals given to the injectors to assist control ?
(5 injection episodes per cylinder per cycle are currently allowed afaik)
and with thanks ...
timebase is the right word
the timebase must be at least 1 ICE cycle (2 revs)
within lesser timebases the fuel rate will exceed 100 kg/hr
so fuel accumulation is allowed - but only within this timebase ?
Yeah. This confirms what Binnotto was saying. Ferrari wanted to simulate what it is like to have the same conerning speeds as Mercedes/RedBull and ran a setup to suit that. Apparently work for 2020. Brazil and Abu Dhabi don't offer the sort of high speed turns that COTA has, so I would say it makes sense. 2019 is done and dusted anyway.Sieper wrote: ↑07 Nov 2019, 16:46photo is clear to me dans79. Mexico and USA have the same (deepest) rear wing, Japan has a less deep rear wing (it also curves up a little bit next to the side plates, that is a good visual indicator).
Mexico at 2200m above sea level requires most DF, USA at sea level (like japan) does not so at least compared to Japan they were indeed running a deep rear wing. What would be more interesting then just the Ferrari wing would be the wings from Mercedes, Redbull and say McLaren for the same 3 tracks as well.
It does confirm that, but, I see with my own eyes that even the less deep rear wing is quite deep (and that confirms what I have heared as well, that Ferrari always runs most DF of the top teams). What we really need is the same pictures from the other teams before we can make real statements on who increased (at least only rear wing DF) most/more. Otherwise we simply have no reference frame.PlatinumZealot wrote: ↑07 Nov 2019, 17:33Yeah. This confirms what Binnotto was saying. Ferrari wanted to simulate what it is like to have the same conerning speeds as Mercedes/RedBull and ran a setup to suit that. Apparently work for 2020. Brazil and Abu Dhabi don't offer the sort of high speed turns that COTA has, so I would say it makes sense. 2019 is done and dusted anyway.Sieper wrote: ↑07 Nov 2019, 16:46photo is clear to me dans79. Mexico and USA have the same (deepest) rear wing, Japan has a less deep rear wing (it also curves up a little bit next to the side plates, that is a good visual indicator).
I got your explanations (which are strikingly similar to some I found in an article on another website), but they and this comment of yours don't really satisfy my request for an educated technical opinion on the feasibility of a pulsed fuel inflow to the FFM in the assumption that, as you said, there is no pulse-generating pump. Concerning the fuel injection sensors, to my (surely incomplete) knowledge, the way the fuel flow is measured in the injection system, if anything, opens more avenues to speculation than it closes.saviour stivala wrote: ↑07 Nov 2019, 04:41"The part of the fuel system called all in the fuel tank" explains how that part of the fuel system works. "The part of the fuel system called all on the engine" explains how that part of that fuel system works. As to what I think, which of course will only be my personal opinion. If a formula one team of the caliber, capability and experience of RBR says that the fuel flow sensor/meter can be made to show a false reading other than the actual fuel flow that passes through it. Only a fool will not believe RBR. I also 'think', which of course is only my personal opinion. that if the fuel flow sensor/meter is made to show a false reading other than the actual fuel flow that passes through it. only a fool will believe that the FIA will not be able to notice that with all the controlling means they have.ncx wrote: ↑07 Nov 2019, 00:00Do you think there is no way to modulate significantly the fuel flow into the FFM by means of devices that are inconspicuous enough to pass scrutiny?saviour stivala wrote: ↑06 Nov 2019, 22:56Further to “the part of the fuel system called all in the fuel tank”,
PlatinumZealot wrote: ↑07 Nov 2019, 17:30Pulsating flow is a pretty standard problem for fuel flow meters. There are different ways of handling it. Just increase the sampling rate. And yes as you rightly said, there will be some time base that the system is damped to. Teams still wouldn't get much time to use their new found power boost, Because Ferrari want this boost for a few seconds, not milliseconds.Tommy Cookers wrote: ↑07 Nov 2019, 13:08this is not truesaviour stivala wrote: ↑07 Nov 2019, 09:56.... all fuel flow through the injectors the final point of the flow system including the fuel pressure and temperature goes through the FIA data logger.
and with thanks ...
Simple problem though. Put two flow meters. One after the low pressure pump and one for the return. And count injector rail pressure and injector pulse widths. Any discrepancies will be easily found out. For a higher fuel flow you have to use either A) higher fuel pressure, or B) longer injector pulse widths, or C) additional injection points.
If they accumulate fuel some where in the system, the data from injector pulse widths, fuel return flow, and line pressure should show it up.
http://carbiketech.com/wp-content/uploa ... kit-02.jpg
Fuel accumulation is not allowed, beyond what is contained in the fuel lines.Tommy Cookers wrote: ↑07 Nov 2019, 13:08so fuel accumulation is allowed - but only within this timebase ?
If it is true, that proves that Red Bull and Honda have been experimenting with cheating the fuel flow meter, which has no bearing on whether or not Ferrari have been doing the same.saviour stivala wrote: ↑07 Nov 2019, 04:41"The part of the fuel system called all in the fuel tank" explains how that part of the fuel system works. "The part of the fuel system called all on the engine" explains how that part of that fuel system works. As to what I think, which of course will only be my personal opinion. If a formula one team of the caliber, capability and experience of RBR says that the fuel flow sensor/meter can be made to show a false reading other than the actual fuel flow that passes through it. Only a fool will not believe RBR. I also 'think', which of course is only my personal opinion. that if the fuel flow sensor/meter is made to show a false reading other than the actual fuel flow that passes through it. only a fool will believe that the FIA will not be able to notice that with all the controlling means they have.ncx wrote: ↑07 Nov 2019, 00:00Do you think there is no way to modulate significantly the fuel flow into the FFM by means of devices that are inconspicuous enough to pass scrutiny?saviour stivala wrote: ↑06 Nov 2019, 22:56Further to “the part of the fuel system called all in the fuel tank”,
Both Red Bull and Mercedes have more peak downforce than Ferrari.Sieper wrote: ↑07 Nov 2019, 17:51It does confirm that, but, I see with my own eyes that even the less deep rear wing is quite deep (and that confirms what I have heared as well, that Ferrari always runs most DF of the top teams). What we really need is the same pictures from the other teams before we can make real statements on who increased (at least only rear wing DF) most/more. Otherwise we simply have no reference frame.PlatinumZealot wrote: ↑07 Nov 2019, 17:33Yeah. This confirms what Binnotto was saying. Ferrari wanted to simulate what it is like to have the same conerning speeds as Mercedes/RedBull and ran a setup to suit that. Apparently work for 2020. Brazil and Abu Dhabi don't offer the sort of high speed turns that COTA has, so I would say it makes sense. 2019 is done and dusted anyway.Sieper wrote: ↑07 Nov 2019, 16:46photo is clear to me dans79. Mexico and USA have the same (deepest) rear wing, Japan has a less deep rear wing (it also curves up a little bit next to the side plates, that is a good visual indicator).
