Tommy Cookers wrote: ↑11 Nov 2019, 12:01
afaik imo and fwiw ....
what calibration of fuel injectors ?
this is not traditional cosy injection as in NA V8s (where injection is a steady flow into port air at 1 bar)
here we have DI ....
multiple timed high-rate injections against gas pressure going from 4 bar to maybe 150 bar by tdc ( and more after tdc)
there is no mandated calibration for this
and nothing that is a standard applicable to all engines at all times
each engine type will have its own in-use relationship between injector signals and fuelling outcomes
ok the injectors control the mass flow but they don't measure the mass flow
nothing can consistently be used to contravene indicated-legal fuel rates from mandated officially-calibrated fuel rate meters
yes it would be interesting to know what fuelling violations were determined in the 2 or 3 cases of contravention
and btw ....
(A) the fuel rate rules require engines to run eg all steady rpm from 10500 to 12100 on no more than 100kg/hr
but the designer might prefer to have constant ideal AFR accelerating through this rpm range
this requires iirc about 1.5 gm of fuel held back for 1 sec so that the average fuel rate accelerating is 100 kg/hr
isn't this possible without breaking fuel line rules ?
and isn't this FIA-accepted/manufacturer-intended ? - (just don't call it fuel accumulation !)
(B) in the 10500 rpm thread it was shown that they now run 10300 to 11900 rpm
the displayed sampled rpm value over-reads the true on-upshift rpm so aren't they really running 10150 to 11750 rpm ?
much reducing the fuel hold-back needed for constant AFR acceleration and helping in 'steady' running at constant AFR
isn't (B) the result of the historic scrutiny and pressure over (A) ?
