From my observations it's the highest strat mode used during the race. Paired ofc with some HPP setting and use of the overtake button and probably some more settings.
This is not naturally aspirated 22,000 rpm engines any more. There is not much of a difference on power between new and old engines. In naturally aspirated engines you can do much to make up for blow-by.. In turbo engine you can use just that little bit more of boost.Just_a_fan wrote: ↑18 Nov 2019, 11:33Lewis has used 3 engines for the season, Gasly has used 7. The unit in Gasly's car was fresher and he was using everything it had - he said in the cool down room that he was holding the overtake button the whole way.
The fresher engine can be more safely run in higher performance modes for longer than a rules-compliant engine that has already done most of its expected working life. All of the engines are run in a performance-limited mode for most of their lives with periods of high performance output rationed by the teams for reliability reasons.PlatinumZealot wrote: ↑18 Nov 2019, 15:44This is not naturally aspirated 22,000 rpm engines any more. There is not much of a difference on power between new and old engines. In naturally aspirated engines you can do much to make up for blow-by.. In turbo engine you can use just that little bit more of boost.Just_a_fan wrote: ↑18 Nov 2019, 11:33Lewis has used 3 engines for the season, Gasly has used 7. The unit in Gasly's car was fresher and he was using everything it had - he said in the cool down room that he was holding the overtake button the whole way.
This is what helped Redbull being more competitive in races this season as well. With multiple PUs planned they used more aggressive modes during the race.Just_a_fan wrote: ↑18 Nov 2019, 16:59PlatinumZealot wrote: ↑18 Nov 2019, 15:44This is not naturally aspirated 22,000 rpm engines any more. There is not much of a difference on power between new and old engines. In naturally aspirated engines you can do much to make up for blow-by.. In turbo engine you can use just that little bit more of boost.Just_a_fan wrote: ↑18 Nov 2019, 11:33
This is why the teams tell the driver what strat mode to use, and why the drivers ask for more power - they're saying "give me permission to run the engine at its maximum" because they know that the engines won't last for the requisite number of events if they just turn them up as and when they see fit.
Exactly. In effect they have given themselves an engine performance improvement over their competitors by taking penalties at other events. They are mimicking the greater performance of the Mercedes from a few years ago by running a younger engine at high outputs than their competitors. Of course, Mercedes did it by having a better unit, but the Red Bull approach gives the same effect.
The power target is still the same for relevant modes. An engine to be used in its last race will have the same output target as that in its first race. This is why the teams manage the power modes to ensure that they have reliable output.Just_a_fan wrote: ↑18 Nov 2019, 16:59The fresher engine can be more safely run in higher performance modes for longer than a rules-compliant engine that has already done most of its expected working life. All of the engines are run in a performance-limited mode for most of their lives with periods of high performance output rationed by the teams for reliability reasons.PlatinumZealot wrote: ↑18 Nov 2019, 15:44This is not naturally aspirated 22,000 rpm engines any more. There is not much of a difference on power between new and old engines. In naturally aspirated engines you can do much to make up for blow-by.. In turbo engine you can use just that little bit more of boost.Just_a_fan wrote: ↑18 Nov 2019, 11:33
The engines have an allocation of high output that the teams can use. The engine can't be run flat out constantly or it will fail. It's possible that an engine near the end of its expected life can't be run in maximum mode at all - the team may have used up the allocation in earlier races in order to secure more points then. It's a trade off.
As an example, remember Brasil '17 when Hamilton started from the pit lane with a fresh engine and the team just said "go for it" and gave him all of the engine modes he wanted? That wouldn't have been possible with a 5- or 6-race old engine.
If the power is the same for all modes, why have the modes? Why does "party mode" give greater performance if the power is the same?PlatinumZealot wrote: ↑18 Nov 2019, 18:04The power target is still the same for relevant modes. An engine to be used in its last race will have the same output target as that in its first race. This is why the teams manage the power modes to ensure that they have reliable output.
Respective modes obviously!Just_a_fan wrote: ↑18 Nov 2019, 19:50If the power is the same for all modes, why have the modes? Why does "party mode" give greater performance if the power is the same?PlatinumZealot wrote: ↑18 Nov 2019, 18:04The power target is still the same for relevant modes. An engine to be used in its last race will have the same output target as that in its first race. This is why the teams manage the power modes to ensure that they have reliable output.
The reality is that the engines are run at a level that gives them reliability for the required number of races. If they could make the things do 7 races in "party mode" they surely would do so. They don't so they have to limit the performance used by the drivers.The available performance is determined broadly in the engine's design but is specific to each engine and its particular use history. That's why the drivers are limited to what modes they can use.
You are still limited because of fuel. Max power probably doesn't change much. What does is stamina.
That's the point, isn't it? The ability to run the PU at maximum output for longer is going to give a real benefit in race pace. If your engine only has to do 1 or 2 races compared to one that has already done 6 races, you're at a distinct advantage of being able to run the PU harder than the other guy.godlameroso wrote: ↑19 Nov 2019, 17:19You are still limited because of fuel. Max power probably doesn't change much. What does is stamina.
That is true. Is there any word on Bottas needing a new ICE?Just_a_fan wrote: ↑19 Nov 2019, 18:43That's the point, isn't it? The ability to run the PU at maximum output for longer is going to give a real benefit in race pace. If your engine only has to do 1 or 2 races compared to one that has already done 6 races, you're at a distinct advantage of being able to run the PU harder than the other guy.godlameroso wrote: ↑19 Nov 2019, 17:19You are still limited because of fuel. Max power probably doesn't change much. What does is stamina.
No decision before next week. The engine burned or lost excessive amounts of oil and shut down precautionary as the tank was empty.godlameroso wrote: ↑19 Nov 2019, 21:44That is true. Is there any word on Bottas needing a new ICE?Just_a_fan wrote: ↑19 Nov 2019, 18:43That's the point, isn't it? The ability to run the PU at maximum output for longer is going to give a real benefit in race pace. If your engine only has to do 1 or 2 races compared to one that has already done 6 races, you're at a distinct advantage of being able to run the PU harder than the other guy.godlameroso wrote: ↑19 Nov 2019, 17:19
Well, as it was burning so much oil, it did not get the performance boost some claim Ferrari get from itMtthsMlw wrote: ↑19 Nov 2019, 22:05No decision before next week. The engine burned or lost excessive amounts of oil and shut down precautionary as the tank was empty.godlameroso wrote: ↑19 Nov 2019, 21:44That is true. Is there any word on Bottas needing a new ICE?Just_a_fan wrote: ↑19 Nov 2019, 18:43
