Formula One's governing body has announced that it has come to a settlement with Scuderia Ferrari after investigations into its 2019 power unit, considered the most powered in F1.
Using the Titomic KF process you could make a unitary head/liner assembly eliminating the head gasket, routing superior cooling gallery geometry that reduces pressure reduction, energy needed by the cooling pump with the combined geometry of the head & liner increasing rigidity while reducing mass, delivering less blow-by at TDC as the liner deformation is reduced at peak cylinder pressure. This would support operating at a even further reduced piston/liner clearance having less geometric variance/distortion during the operating cycle, with a one piece steel or steel liner and composite alloy potentially using the Titomic KF process to have multiple materials. The reduced piston ring to liner friction would be above and beyond normal given the reduced deformation and steel liners having lowest friction. The use of the new graphene enhanced heat transfer nano fluid coolant reducing parasitic cooling losses even further, two innovations that are very symbiotic. The advantages really start to compound on one another bringing a whole new level of performance and efficiency.
Steel liners have been back for a while - the advantage being the range of coatings that can be applied (DLCs of different forms) which do have a big effect on friction as Marc points out.
The reduced deformation also helps oil consumption and blow by.
"As Mercedes has pointed out" that is why I asked him if he can produce any possible link.
I said Marc (the user who originally pointed out steel liners-see above) not Mercedes - I have no idea what they do.
I know from my own experience with highly boosted endurance gasoline engines that compression rings with hard coatings will scrape off any coatings you can possibly apply to an aluminium bore (if they don't fall off on their own at temperaure that is).
The DLC steel liners are well documented and some off the shelf solutions are already available from Mahle - the link below is the first google search result.
If your educated guess based on the fact that the use of steel liners separate from the block casting is the best solution in terms of bore distortion and friction reduction, it must have been the same best solution when F1 engine manufacturers abandoned the use of steel liners even with engines revving past the 20k RPM mark.
I was wondering whether AM might mean they don't need a separate cylinder head. Also you want the piston and its cylinder to expand with heat at the same rate don't you, and so if the piston is AM'd with a steel crown to take more heat it makes sense to do the cylinder in steel too.
And AM can make in steel with more cooling and thin and even hybrid, so it all comes beautifully together, if they've been able to manage it yet
Are the engine materials regulations and limits on what can be used the same now as then? Were they using something then that is no longer allowed?
