But you'd make the halo silver so it's like the ring pull on a can of coke. lol
pazazamadaz wrote: ↑17 Jan 2020, 11:14But you'd make the halo silver so it's like the ring pull on a can of coke. lol
Nothing in F1 is done without reason, what could be possible reasons for this?
I remember when merc and lotus did the blade roll hoop they said the benefit was not aero but weight. I cannot remember was it lower cog or just less mass.the EDGE wrote: ↑17 Jan 2020, 13:51Nothing in F1 is done without reason, what could be possible reasons for this?
Is there a benefit to having a blade roll structure? So the double inlet design depicted by Scarbs would be Mclaren’s tidiest aero solution? Or could the double inlet be the real reason by offering a better aero solution, perhaps for drag or by increasing the effectiveness of the sharkfin?
I wonder if there could be a second raised inlet further behind too, as the side pod inlets have ‘size zero’d’???
That's the effect of the distortion due to the curved reflective surface of the helmet.NathanOlder wrote: ↑17 Jan 2020, 14:14Do those 2 inlets look different in size? One looks higher than the other??
They look a different size in all the pics, not just Carlos reflectionrgava wrote: ↑17 Jan 2020, 15:34That's the effect of the distortion due to the curved reflective surface of the helmet.NathanOlder wrote: ↑17 Jan 2020, 14:14Do those 2 inlets look different in size? One looks higher than the other??
You can see the same distortion in Sainz head (which is not as asymetrical as it seems in the image)
Nice idea but no way the second hump could be as large as in seat fix still and behind. I like scarbs drawing but agree one does look larger and perspective would normally mean the larger one should be smaller, interesting
