Hi everyone. Hope you all had a good Christmas and New years. I was too pushed for time before Christmas to get this update done so here it is now, will mean there'll be another update in around 2 weeks instead of 4.
Ok so for this update I'll be covering issue 12, stages 39 - 42. The actual stages for this issue are small, and often fiddly, there are a lot of minor components to be attached and what not so there'll be a lot of photos and not a great deal of info. Enjoy!
So first up, stage 39. Assembling the rear suspension pushrods. Parts supplied with this issue were: Bellcrank top left (top left), bellcrank lower left (top 2nd from the left), bellcrank lower right (top 2nd from the right), bellcrank top right (top right) & rear pushrods x 2 (bottom).
Parts needed from previous stages were:
- Right and left rear shock absorbers (stage 34)
Ok so firstly one of the pushrod eyes was slotted over the corresponding pin on the left bellcrank top. The pushrods do not have a right and left orientation, but they do have a front and back so care was taken to orientate the pushrods so the 'tail' of the wing profile of the arm was facing backwards.
Next up the left rear shock absorber was suspended on the groves on the left bellcrank lower.
Then the the bellcrank upper and lower parts were screwed together.
This was then repeated for the right bellcrank and shock absorber.
The ends of the pushrods were also inked (not pictured)
Next up stage 40: Assembling the gearbox part 3. Parts supplied with this issue were: rear suspension mounting plate front (top left), rear anti roll bar ( middle left), rear suspension mounting plate rear (bottom left), gearbox upper (top right), hose B (bottom right).
Parts required from previous stages were:
- Gearbox oil line adapter, bolts 1 x 3 & 2 x 2 and the brake T-line piece (stage 34)
- Left and right rear shock reservoirs (stage 36)
- left and right rear shocks and bellcrank assemblies (stage 39)
First up the gearbox oil line adapter was glued to the gearbox upper.
Next up the bolt 1s & 2s were removed carefully from the sprue, care was taken due to how small the bolts were. The scale of these bolts once again impressed me, I'm not sure if these will be visible on the final model or not but again it's nice to know that they're there.
The bolts 1 x 3 were placed into the corresponding holes in the gearbox upper.
Next up the bolts 2 x 2 were placed into their corresponding holes in the gearbox upper.
The bolts were secured with a small amount of glue on the rear surfaces.
Next up a 19mm, and 135mm length of hose B were cut. The ends of these were sealed with a small amount of plastic adhesive to stop them fraying. Was a little bit tricky to cut these to the right length due to how curled up the hoses were, I can't imagine it will make much difference though and they're all within +/-2mm of the intended lengths anyway.
The 135mm length of hose was glued to the correct pin on the T-piece.
Next up the 2 x 19mm length of hose were attached to the shock reservoirs and shock absorbers correspondingly.
Next up stage 41. Assembly of the gearbox part 4. Parts supplied with this issue were: left quarter panel (bottom left), toelink bracket (top right), left toelink (middle right), left rear upper wishbone (bottom right).
- Gearbox oil line union (stage 34)
- Gearbox assembly (stage 38)
- Rear suspension mounting plate front + rear, left and right rear suspension assemblies & hose B (stage 40)
First up the gearbox oil line union was removed from the sprue and glued with a small amount of glue into the hole on the right side of the gearbox assembly.
Following this a 68mm length of hose B was cut and sealed as previous. This was then glued onto the pin end of the gearbox oil line union.
Following this the rear suspension mounting plate rear section was slotted into the gearbox assembly, and screwed in place. Care was taken to orientate it correctly in respect to front and rear.
Next up the left and right rear suspension assemblies, and rear suspension mounting plate front part were screwed to the corresponding holes on the gearbox, this was A) quite tricky to do without letting other pieces fall off and B) fiddly due to the shape and locations of the holes, so I've taken photos of the completed gearbox assembly prior to the final attachment of the reservoirs to the gearbox, and some when they were glued.
Next up stage 42, assembly of the gearbox part 5. Parts supplied with this issue were: Right quarter panel (top), right rear upper wishbone (bottom left), right toelink (bottom middle), toelink bracket (bottom right).
- Drop links x 2 (stage 34)
- Rear lower wishbone assembly (stage 38)
- Rear anti-roll bar, gearbox upper, brake line T-piece assembly (stage 40)
- Toelink bracket (stage 41)
- Gearbox assembly (stage 41)
First up the rear lower wishbone was slotted into the gearbox making sure that it was the right way up. At this point I noticed that I had screwed one of the brackets onto the gearbox upside down so I rectified this first. After this was sorted then I screwed through the brackets on the gearbox into the wishbone.
Following this the pushrods were were screwed into the brackets on the wishbone assembly. Really starts coming together when these are in. Care was taken not to overtighten the screws.
Next the brake line T-piece was glued to the gearbox upper. As much care was taken as possible to get the T-piece perpendicular to the rest of the assembly.
Following this the gearbox upper sub-assembly was screwed to the gearbox assembly.
At this point the toelink bracket was screwed to the left side of the gearbox.
Next up the drop links were removed from the sprue.
These were then slotted onto the pins on the bellcrank assemblies so that the droplink pins were facing upwards Please note the position of the hose B coming from the T-piece being positioned forwards and downwards so it will not interfere with the anti-roll bar.
Following this the anti roll bar was slotted onto the drop link pins, and slots in the suspension mount plates.
And that's it for this update everyone. Sorry for the long winded post, I imagine they're going to continue in the same vein as it's in quite a detailed and fiddly part of the build. Thanks for reading and as usual if there's any requests for further detail just let me know.
Thanks.
Alex
