Yesterday posted on Youtube.
you mean like Monaco, oh wait it is even worse at MonacoJust_a_fan wrote: β13 Feb 2020, 14:11Can't help thinking this is going to be another Hungaroring. One overtake possibility at the end of the start/finish straight, the rest of the lap is going to be processional stuff.
The elevation changes look like it should be a fun track to drive for the drivers, requiring concentration to ensure lines are spot on in to blind corners etc.
I'd take Monaco off the calendar. I've been quite vocal in my opposition to it as a realistic race for F1 cars. Have it as a show, by all means, but not as part of the title series.Capharol wrote: β13 Feb 2020, 17:03you mean like Monaco, oh wait it is even worse at MonacoJust_a_fan wrote: β13 Feb 2020, 14:11Can't help thinking this is going to be another Hungaroring. One overtake possibility at the end of the start/finish straight, the rest of the lap is going to be processional stuff.
but to be honest, there are several tracks where you have little opportunity to overtake, so not much of a difference to those tracks
Edit: i even think after the Hugenholzbocht you can overtake aswell because of the long (almost) straight till Scheivlak
No guarantee of that, at all. The rules aren't promising much easier overtaking, they're intended to allow closer running. The track still has to facilitate overtakes. It's not going to be a case that every track will be awash with overtaking - it's just not going to be that way.
we will see in a few monthsJust_a_fan wrote: β13 Feb 2020, 20:11I'd take Monaco off the calendar. I've been quite vocal in my opposition to it as a realistic race for F1 cars. Have it as a show, by all means, but not as part of the title series.Capharol wrote: β13 Feb 2020, 17:03you mean like Monaco, oh wait it is even worse at MonacoJust_a_fan wrote: β13 Feb 2020, 14:11Can't help thinking this is going to be another Hungaroring. One overtake possibility at the end of the start/finish straight, the rest of the lap is going to be processional stuff.
The elevation change along with the very-single-line feel of the curves after Hugenholzbocht on that video (and others seen around the place) suggest that it won't present an opportunity. There's just not enough time in that sequence of bends to get a run on someone ahead.
Why so negative? Hungaroring's main straight is ~750m, Suzuka is ~920m and zandvoort's is ~1km. And in zandvoort exit speed from second to last corner is quite high already, which is the oposite of those two tracks. High exit speed means cars will hit their drag limit (or at least gettint close to it) earlier in the main straight , allowing following car to start gaining sooner.Capharol wrote: β13 Feb 2020, 20:47we will see in a few monthsJust_a_fan wrote: β13 Feb 2020, 20:11I'd take Monaco off the calendar. I've been quite vocal in my opposition to it as a realistic race for F1 cars. Have it as a show, by all means, but not as part of the title series.Capharol wrote: β13 Feb 2020, 17:03
The elevation change along with the very-single-line feel of the curves after Hugenholzbocht on that video (and others seen around the place) suggest that it won't present an opportunity. There's just not enough time in that sequence of bends to get a run on someone ahead.![]()
Exactly what I wanted to say but why debatte/discuss with others when they made up their mind.Juzh wrote: β14 Feb 2020, 00:14Why so negative? Hungaroring's main straight is ~750m, Suzuka is ~920m and zandvoort's is ~1km. And in zandvoort exit speed from second to last corner is quite high already, which is the oposite of those two tracks. High exit speed means cars will hit their drag limit (or at least gettint close to it) earlier in the main straight , allowing following car to start gaining sooner.Capharol wrote: β13 Feb 2020, 20:47we will see in a few monthsJust_a_fan wrote: β13 Feb 2020, 20:11
Slow corner exits need absurdly long straight in order to recover ground lost during the inital acceleration phase.
I'm willing to bet overtaking will not be a problem here, even if it's only going to happen on the main straight, but that's the case for most tracks anyway.
The Grand Prix of the Netherlands on Circuit Zandvoort can take place definitively, at least if it is up to the municipality of Zandvoort. The municipality has issued the required event permit. Circuit Zandvoort now only needs to get a Grade One license from the FIA, although that is normally a formality.
